Need BOM for a core switch
mehtdi1980
Can you help me to provide information where i can find the BOM (Bill of Materials) for the switch with following specs ?
• Two core switches are required for  redundancy on the architecture level.
• Every switch shall be fully redundant in  power supplies and supervisor engines.
e Core switches are used to build a  collapsed core layer which is responsible for routing
functions, aggregating 10 Gig uplinks from  access layer and hosting servers.
10 GE ports shall be equipped  with original X2 interfaces from same manufacturer of the
core switches.
• Each of the two core switches should  meet the following minimum specs:
o Rack mount Modular chassis with a  minimum of 1 free slot after installing all modular
components.
o Must have passive backplane  architecture.
o Must be configured with redundant power  supplies.
o Must be configured with a  supervisory or control module and minimum  512MB RAM
expandable to 1GB.
o Must have a minimum redundant switching  capacity of 720Gbps.
o The supervisory module must have at  least two 10 Gigabit Ethernet ports equipped
with two SR X2 modules.
o Must be configured with (1) one 4-port  10Gigabit Ethernet modules fully populated
with the correct  type of XENPAK's (X2). XENPAK's (X2) must be provided by the same
         manufacturer providing the switches for compatibility and optimum performance.
o One 48 10/100/1000 ports fabric enabled  module must be installed with DFC card for
servers connectivity
o One 48 Gig SFP ports module must be  installed and equipped with the required SFPs.
o One 48        10/100/1000    ports fabric enabled module  to connect Call Center agent
workstations and IP  Phones.
Thanks in Anticipation
Ganesh Hariharan
core switches.
components.
expandable to 1GB.
Check out the below product items for the above requirement
WS-C6513-FWM-K9    Cisco Catalyst 6513 Firewall Security System
S733ESK9-12218SXF    Cisco CAT6000-SUP720 IOS ENTERPRISE SERVICES SSH
CF-ADAPTER-SP    SP adapter  for SUP720 and SUP720-10G
MEM-SUP720-SP-1GB    Catalyst 6500 1GB SP memory for Sup720 and Sup720-3B
MEM-MSFC3-1GB    1GB Mem for Sup720, Sup720-3B and MSFC2A
WS-SUP720-3B    Catalyst 6500/Cisco 7600 Supervisor 720 Fabric MSFC3 PFC3B
WS-X6748-SFP    Catalyst 6500 48-port GigE Mod: fabric-enabled (Req. SFPs)
GLC-SX-MM    GE SFP, LC connector SX transceiver
WS-X6748-GE-TX    Cat6500 48-port 10/100/1000 GE Mod: fabric enabled, RJ-45
WS-CAC-6000W    Cat6500 6000W AC Power Supply
CAB-AC-2500W-EU    Power Cord, 250Vac 16A, Europe
MEM-C6K-CPTFL512M    Catalyst 6500 Sup720/Sup32 Compact Flash Mem 512MB
BF-S720-64MB-RP    Bootflash for SUP720-64MB-RP
Just cross check the line items with your requirement most of them should cover.
Hope to help !!
Ganesh.H
If helpful do rate the post
