Need clarification on attaching usb thumb drive to switch/router
sdavids5670
Level 2
Level 2
Does a usb thumb drive need to be attached to the usb port at bootup for the usbx: to be present at the CLI or should I be able to connnect/disconnect a thumb drive to switch at any time to access files?  I have a WS-C4500X-32 that's not seeing the usb0: drive though I have a thumb drive connected.  Or is there something I need to do at the CLI to initialize the usbx: disk?
Wilson Bonilla
Level 3
Level 3
Hello
Just like a compact flash, the usb driver can be connected at any moment, that shouldn't be a problem.
Please check compatibility, 4500x supports usb-x45-4gb-e usb driver, please check compatibility
USB ports
USB Type A interface (top connector) provides access to an external USB FLASH device (also known as a thumb drive or a USB key). The interface supports the 4-GB Cisco USB flash drive (Cisco part no. USB-X45-4GB-E). The Cisco IOS software provides standard file system access to the flash device: read, write, erase, and copy, as well as formatting of the flash device with a FAT file system. You can boot the switch from the USB drive
Note Currently, there is no support for the USB B-port (bottom connector).
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500x/installation/notes/OL_24795.html
Regards.
Wilson B.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Don't know for 4500X but on many other Cisco devices, just inserting the USB drive is sufficient, although often there's limitations on how the USB is formatted, its capacity and/or brand.
Wilson Bonilla
Level 3
Level 3
Hello
USB ports
Regards.
Wilson B.
Thanks for the help.  I was trying to use a thumb drive that wasn't compatible.  Mine was 16 GB.  When I plugged a 2 GB drive in the usb port it came right up and I was able to access it.  Thanks!
Glad to hear it worked.
Regards.
Wilson B
