Need help configuring NEC Ip Phone DT700 on cisco switch 3750 and 3560
supportti
Hello we have a core switch 3750 and 3560 that are all connected to the core
We are configuring IP Phone (Nec DT700)
Here is the config of a port im testing on the 3750.  Ive add the line "auto qos voip trust" and here what look like my interface
interface GigabitEthernet1/0/47
description TEST IP PHONE WITH PC
switchport access vlan 80
switchport mode access
switchport voice vlan 75
srr-queue bandwidth share 1 30 35 5
priority-queue out
mls qos trust cos
auto qos trust
spanning-tree portfast
end
it add those line to the core switch too
mls qos map cos-dscp 0 8 16 24 32 46 48 56
mls qos srr-queue input bandwidth 70 30
mls qos srr-queue input threshold 1 80 90
mls qos srr-queue input priority-queue 2 bandwidth 30
mls qos srr-queue input cos-map queue 1 threshold 2 3
mls qos srr-queue input cos-map queue 1 threshold 3 6 7
mls qos srr-queue input cos-map queue 2 threshold 1 4
mls qos srr-queue input dscp-map queue 1 threshold 2 24
mls qos srr-queue input dscp-map queue 1 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue input dscp-map queue 1 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue input dscp-map queue 2 threshold 3 32 33 40 41 42 43 44 45
mls qos srr-queue input dscp-map queue 2 threshold 3 46 47
mls qos srr-queue output cos-map queue 1 threshold 3 4 5
mls qos srr-queue output cos-map queue 2 threshold 1 2
mls qos srr-queue output cos-map queue 2 threshold 2 3
mls qos srr-queue output cos-map queue 2 threshold 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 0
mls qos srr-queue output cos-map queue 4 threshold 3 1
mls qos srr-queue output dscp-map queue 1 threshold 3 32 33 40 41 42 43 44 45
mls qos srr-queue output dscp-map queue 1 threshold 3 46 47
mls qos srr-queue output dscp-map queue 2 threshold 1 16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 2 threshold 1 26 27 28 29 30 31 34 35
mls qos srr-queue output dscp-map queue 2 threshold 1 36 37 38 39
mls qos srr-queue output dscp-map queue 2 threshold 2 24
mls qos srr-queue output dscp-map queue 2 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3 0 1 2 3 4 5 6 7
mls qos srr-queue output dscp-map queue 4 threshold 1 8 9 11 13 15
mls qos srr-queue output dscp-map queue 4 threshold 2 10 12 14
mls qos queue-set output 1 threshold 1 100 100 50 200
mls qos queue-set output 1 threshold 2 125 125 100 400
mls qos queue-set output 1 threshold 3 100 100 100 400
mls qos queue-set output 1 threshold 4 60 150 50 200
mls qos queue-set output 1 buffers 15 25 40 20
mls qos
Ive ran the command show mls qos interface gig 1/0/47 statistics but im not really sure what to check
GigabitEthernet1/0/47 (All statistics are in packets)
dscp: incoming
0 - 4 : 2849923 0 4580 0 737
5 - 9 : 0 0 0 0 0
10 - 14 : 0 0 0 0 0
15 - 19 : 0 0 0 0 0
20 - 24 : 0 0 0 0 0
25 - 29 : 0 0 0 0 0
30 - 34 : 0 0 0 0 0
35 - 39 : 0 0 0 0 0
40 - 44 : 3469 0 0 0 0
45 - 49 : 0 0 0 729 0
50 - 54 : 0 0 0 0 0
55 - 59 : 0 0 0 0 0
60 - 64 : 0 0 0 0
dscp: outgoing
0 - 4 : 300544064 0 1699 0 45642
5 - 9 : 0 0 0 0 0
10 - 14 : 0 0 0 0 0
15 - 19 : 0 0 0 0 0
20 - 24 : 719 0 0 0 10
25 - 29 : 0 0 0 0 0
30 - 34 : 0 0 0 0 0
35 - 39 : 0 0 0 0 0
40 - 44 : 7624389 0 0 0 0
45 - 49 : 0 2216 0 4616959 0
50 - 54 : 5 0 0 0 0
55 - 59 : 0 0 0 0 0
60 - 64 : 0 0 0 0
cos: incoming
0 - 4 : 2918130 0 0 0 0
5 - 7 : 6415 0 0
cos: outgoing
0 - 4 : 327534339 887 2497 2674 1554
5 - 7 : 8490654 2076 18780062
output queues enqueued:
queue: threshold1 threshold2 threshold3
queue 0: 0 0 0
queue 1: 17343023 2656375 18804772
queue 2: 0 0 633902
queue 3: 0 0 317649800
output queues dropped:
queue 0: 0 0 0
queue 1: 40403 0 3
queue 2: 0 0 8991
queue 3: 0 0 58384
Policer: Inprofile: 0 OutofProfile: 0
How can we know that qos is working...Im not an expert with qos so a little help would be nice
What should i do with trunk port connected to other switch ?
Thanks !
0 Replies 0
