Need help getting simple Nat config to work
david.santel
I can't seem to get the below Nat config to work. I removed the crypto from the fa0/0 for testing.
Why can't i get xlates when I ping 192.168.1.5 or 192.168.1.1? As you can see my access list isnt getting touched?
What am i missing?????
CCC#sh access-lists
Standard IP access list 1
    10 permit 10.10.10.0, wildcard bits 0.0.0.255
CCC#sh ip nat t
CCC#
CCC#sh ip nat s
Total active translations: 0 (0 static, 0 dynamic; 0 extended)
Outside interfaces:
  FastEthernet0/0
Inside interfaces:
  FastEthernet0/1
Hits: 0  Misses: 0
CEF Translated packets: 0, CEF Punted packets: 0
Expired translations: 0
Dynamic mappings:
-- Outside Destination
[Id: 2] access-list 1 interface FastEthernet0/0 refcount 0
[0] prot 6: port #7 refcount 1 syscount 1 localport 4294967295, localaddr 0.0.0.
0, flags 1
[0] prot 6: port #9 refcount 1 syscount 1 localport 4294967295, localaddr 0.0.0.
0, flags 1
[0] prot 6: port #11 refcount 1 syscount 1 localport 4294967295, localaddr 0.0.0
.0, flags 1
[0] prot 6: port #13 refcount 1 syscount 1 localport 4294967295, localaddr 0.0.0
.0, flags 1
[0] prot 6: port #19 refcount 1 syscount 1 localport 4294967295, localaddr 0.0.0
.0, flags 1
[0] prot 6: port #21 refcount 1 syscount 1 localport 4294967295, localaddr 0.0.0
.0, flags 1
CCC#sh run
Building configuration...
Current configuration : 1490 bytes
version 12.4
service timestamps debug uptime
service timestamps log uptime
hostname CCC
boot-start-marker
boot system flash c2600-adventerprisek9-mz.124-25d.bin
boot-end-marker
no aaa new-model
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
no ip domain lookup
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
archive
log config
  hidekeys
crypto isakmp policy 2
encr 3des
hash md5
authentication pre-share
group 2
lifetime 400
crypto isakmp key cisco123 address 1.1.1.3
crypto ipsec transform-set Petaluma_VPN ah-sha-hmac esp-3des
crypto map Petaluma_1 1 ipsec-isakmp
! Incomplete
set peer 1.1.1.3
set transform-set Petaluma_VPN
match address 100
ip address 1.1.1.2 255.255.255.0
ip nat outside
ip virtual-reassembly
speed auto
half-duplex
interface Serial0/0
no ip address
shutdown
clock rate 56000
interface FastEthernet0/1
ip address 10.10.10.1 255.255.255.0
ip nat inside
duplex auto
speed auto
router rip
network 1.0.0.0
network 10.0.0.0
no ip forward-protocol nd
ip route 192.168.1.0 255.255.255.0 1.1.1.3
no ip http server
no ip http secure-server
ip nat source list 1 interface FastEthernet0/0 overload
access-list 1 permit 10.10.10.0 0.0.0.255
control-plane
line con 0
line aux 0
line vty 0 4
login
end
cadet alain
Can you do the test again without the crypto map and  do sh ip nat translation and if you see nothing then repeat but with the following debug on: debug ip nat.
But if you want traffic to get through the vpn tunnel you'll have to exempt it from being natted with a deny clause in an extended access-list.
Regards.
Alain.
I am getting same issure:
Dynamic mappings:
[Id: 1] access-list NAT interface FastEthernet0/0 refcount 0
[0] prot 6: port #0 refcount 2 syscount 2 localport 4294967295, localaddr 0.0.0.
0, flags 1
0, flags 1 Dynamic mappings:
0, flags 1
0, flags 1
I don't know what this means and will try debug ip nat and get a readout.
