Clocking Resources for 2 PRI's Question
Yort Mantup
Level 4
Level 4
I have a 2821 router with a PRI from one carrier plugged into Controller T1 0/0/0, T1 (PtP) in 0/1/1, and a 2nd PRI from a different carrier plugged into Controller T1 0/3/0.
The 0/3/0 PRI is new and am bringing it up for testing. The service works but I am getting avg 900 slip seconds on it.  Current clocking looks like this:
clock timezone EST -5
clock summer-time EDT recurring
no network-clock-participate slot 1
network-clock-participate wic 0
no network-clock-participate wic 1
network-clock-participate wic 3
network-clock-select 1 T1 0/0/0
I am unsure how to resolve. I do have a NM-HD-2V installed and unused in Slot 1 on the router.  I was thinking of moving the VWIC2 card there along with the new PRI connection in hopes of creating a separate clocking domain, but unsure if that will work.
Looking for some help..
Thanks!
acampbell
Perhaps you could share with us the set up of yor T1 controlers.
Have you set the T1 lines to be line clocked or internal
show controller t1
Also this link may help
http://www.cisco.com/en/US/tech/tk713/tk628/technologies_tech_note09186a00801095a3.shtml#topic2
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
PRI (1) Controller
T1 0/0/0 is up.
  Applique type is Channelized T1
  Cablelength is long 0db
  No alarms detected.
  alarm-trigger is not set
  Soaking time: 3, Clearance time: 10
  AIS State:Clear  LOS State:Clear  LOF State:Clear
  Version info Firmware: 20090408, FPGA: 13, spm_count = 0
  Framing is ESF, Line Code is B8ZS, Clock Source is Line.
  CRC Threshold is 320. Reported from firmware  is 320.
PtP Controller
T1 0/1/0 is up.
  Description: T1 to Sparks-GR
  No alarms detected.
  Data in current interval (371 seconds elapsed):
PRI 2 (new) - currently down
T1 0/3/1 is down.
  Transmitter is sending remote alarm.
  Receiver has loss of signal.
