need help in 1900 router
yazeed.ak
Dear all,
i faces a problem with cisco 1900 router
the host in the diagram unable to ping the next hop (172.29.18.125)..
all pings and traceroute stops at the middle router,,
i chechek ip route..but i don't know where is the problem..
help me please :-(
this is the show run command and atached the diagram of the system
R1#show
R1#show conf
R1#show configuration ru
R1#show configuration run
R1#show run
R1#show running-config
Building configuration...
Current configuration : 1973 bytes
! Last configuration change at 12:43:27 UTC Mon Feb 11 2013 by admin
! NVRAM config last updated at 12:38:40 UTC Mon Feb 11 2013 by admin
version 15.1
hostname Axiom-SIP-router
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
no ip domain lookup
license udi pid CISCO1921/K9 sn FCZ15349110
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description Inside-Local
ip address 172.27.3.10 255.255.255.0
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
description Outside-To-STC
ip address 172.29.18.126 255.255.255.252
duplex auto
speed auto
interface GigabitEthernet0/1.1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 172.29.18.125
ip route 10.205.20.50 255.255.255.255 172.29.18.125
ip route 172.16.1.0 255.255.255.0 172.27.3.1
ip route 172.16.2.0 255.255.255.0 172.27.3.1
ip route 172.16.3.0 255.255.255.0 172.27.3.1
ip route 172.16.4.0 255.255.255.0 172.27.3.1
ip route 172.27.0.0 255.255.254.0 172.27.3.1
ip route 172.27.5.0 255.255.255.0 172.27.3.1
ip route 192.168.150.0 255.255.255.0 172.27.3.1
access-list 110 permit ip any any
Reza Sharifi
Does the host have the correct default gateway (172.27.3.10)?
also, can you post "sh ip route" from the 1900 router?
mhnedirli
can you ping the 172.29.18.126
Dear Raza,
yes i can ping 172.27.3.10, and i put it as a gateway of the PC
this is the show ip route:
Gateway of last resort is 172.29.18.125 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 172.29.18.125
      10.0.0.0/32 is subnetted, 1 subnets
S        10.205.20.50 [1/0] via 172.29.18.125
      172.16.0.0/24 is subnetted, 4 subnets
S        172.16.1.0 [1/0] via 172.27.3.1
S        172.16.2.0 [1/0] via 172.27.3.1
S        172.16.3.0 [1/0] via 172.27.3.1
S        172.16.4.0 [1/0] via 172.27.3.1
      172.27.0.0/16 is variably subnetted, 4 subnets, 3 masks
S        172.27.0.0/23 [1/0] via 172.27.3.1
C        172.27.3.0/24 is directly connected, GigabitEthernet0/0
L        172.27.3.10/32 is directly connected, GigabitEthernet0/0
S        172.27.5.0/24 [1/0] via 172.27.3.1
      172.29.0.0/16 is variably subnetted, 2 subnets, 2 masks
C        172.29.18.124/30 is directly connected, GigabitEthernet0/1
L        172.29.18.126/32 is directly connected, GigabitEthernet0/1
S     192.168.150.0/24 [1/0] via 172.27.3.1
Dear Mhnedirli,
yes i can :-(
what kind of host is this ? Is this a PC( which OS ?) or is this a router with no ip routing ? in which case have you got the ip default-gateway command configured ?
Also does R2 have a route back to the subnet the PC is in ?
Alain
