need help in shaping policy-map with bw gurantee .
Dr.X
Level 2
Level 2
hi all ,
assume i have a class map x and i have policy map y
now in have  policy-map y macthed the class x and gave it gurantee bw 1 Mbps
and left the class default without modification.
the quewstion is
how to  give certian limit to the policy-map as all ???
i mean that i want to limit the traffic by shaping it to 2 Mbps ,
how do it ?
can any one give me  sample example ?
what i want to do is , i want to apply    QOS  and in same time i want to limit speed  by shaping to specific value .
i dont want to use police , i will try shape cause it better .
regards
Hello
Not sure I understand your question  - However  you dont need to define a specific class-map to shape all traffic, you can use the class-default
policy-map SHAPE
class class-default
shape average 2000000
int xxx
description WAN interface
service-policy output SHAPE
If this isn't what you require please elaborate.
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
hi ,
you missunderstood me
assume i have an interface fast0/1
assume topology belwo
lan====f0/1routerf0/0========================internet
max  speed allowed from internet is 4 ADSL Mbps
ok ?
now
on the lan side
i want to make qos to gurantee bw on nbar protocol and in the same time i dont want the speed reach more than 2 M
i know that i can do policy map thatg match nbar and give it bw gurantee 1m for (2 total)
now how to limit this policy map to 2 M
note that if id didnt limit it , it will reach 4 ,M
but agian
i want to gurantee & limit in the same time
did u understand my question now ?
wish dat
regards
