Need Help on my project ( college project )
Hi any one can help for the ip scheming for the item below
1. Catalyst 3750 1 unit
2. Catalyst 2960 24 port 4 units
3. Wireless controller for the cisco areonet 4 units
4. Router 2801
5 . 6 units of the IBM SERVER for diffrent task
6. 1 units the IBM STORAGE
if some one can help me please help on drawing explaination . And the suggested ip
viswamin
Hi Mohd Amir,
It all depends how you want to design your network like
Do you want to have hosts in different network. if so how many host per network. only when we get this details we can decide on how many network we would need and what is the IP addressing schema that can be used?
-Vijay
Hi vijay
i try get the detail for you n get back to you
N
