Need help on netflow on 6500 switch
steve switzer
Hi All
I am currently configuring a 6500 to send data to a stealthwatch xe Netflow device.
I though i has this correctly configured using the following config -
ip flow-export source Loopback0
ip flow-export version 5
ip flow-export destination (ip add) 9000
On the various interfaces i wish to get flow data from (vlans ) i have put the following -
ip flow ingress
Now until recently i thought i was seeing all the flows but was informed by the support for the device i needed to put in the following -
ip flow-cache timeout inactive 10
ip flow-cache timeout active 1
mls netflow interface
mls nde sender version 5
Now when i do the following command - sh ip flow export - i get this -
Flow export v5 is enabled for main cache
Export source and destination details :
VRF ID : Default
Source(1) x (Loopback0)
Destination(1) x (9000)
Version 5 flow records
51204 flows exported in 13346 udp datagrams
0 flows failed due to lack of export packet
0 export packets were sent up to process level
0 export packets were dropped due to no fib
0 export packets were dropped due to adjacency issues
0 export packets were dropped due to fragmentation failures
0 export packets were dropped due to encapsulation fixup failures
0 export packets were dropped enqueuing for the RP
0 export packets were dropped due to IPC rate limiting
0 export packets were dropped due to Card not being able to export
Netflow Data Export enabled
Exporting flows to 10.61.236.171 (9000)
Exporting flows from 10.253.34.1 (59187)
Version: 5
Layer2 flow creation is enabled on vlan 1,10,50,197,239,251,253
Layer2 flow export is enabled on vlan 1,10,50,197,239,251,253
Include Filter not configured
Exclude Filter not configured
Total Netflow Data Export Packets are:
0 packets, 0 no packets, 0 records
Total Netflow Data Export Send Errors:
IPWRITE_NO_FIB = 0
IPWRITE_ADJ_FAILED = 0
IPWRITE_PROCESS = 0
IPWRITE_ENQUEUE_FAILED = 0
IPWRITE_IPC_FAILED = 0
IPWRITE_OUTPUT_FAILED = 0
IPWRITE_MTU_FAILED = 0
IPWRITE_ENCAPFIX_FAILED = 0
IPWRITE_CARD_FAILED = 0
Netflow Aggregation Disabled
  • •a. Is this working correctly ?
  • •b. If so why do i see nothing when i do a - show mls nde
I think you will agree that looks ok
However when i do this co mmand - sh mls nde - i get this -
Exporting flows to x (9000)
Exporting flows from x (59187)
Version: 5
IPWRITE_NO_FIB = 0
IPWRITE_PROCESS = 0
Now - what i need to know is
If it is ok then why am i seeing nothing coming from the nde - why are there no data export packets ?
We are now heavily invested in this technology for a medium sized organisation and i need to know if this is working correctly
Kind Regards
Steve
jakewilson
I'm no NetFlow Ninja however, I am a Lancope and Scrutinizer supporter. If you contact us and send a packet capture of the netflow data grams I can take a quick look and let you know what you need to fix.
