Need Help setting up IP routing on cisco catalyst 1000
peterdorris1
I am trying to configure my Cisco Catalyst C1000-8T-E-2g-L for inter-VLAN routing. I need to route 172.25.X.X traffic through 172.26.X.X and vice versa. I have two VLANs set up but cannot figure it out past there. I am working in the GUI. any help would be appreciated.
Hello @peterdorris1
 With commamd lline, you should run the commamd  "ip routing".
However, this switch seems to be only layer2 and you can not do inter vlan routing in l2 switches.
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-1000-series-switches/nb-06-cat1k-ser-switch-ds-cte-en.html
M02@rt37
Hello @peterdorris1,
By default, the device is in L2 switching mode and IP routing is disabled. To use the L3 capabilities of the device, you must enable IP routing.
Device(config)# ip routing
Best regards
