Need help to convert cisco 2960 config to cisco 9300 switch.
vijay.kumar23
Hi, Please help to convert 'Need help to convert cisco 2960 config to cisco 9300 switch.'
What commands yoh face issue with ?
MHM
Hi MHM,
Thanks for your reply.
I Need to convert the below QOS configuration. please check and help to convert.
mls qos map cos-dscp 0 8 16 24 32 46 48 56
mls qos srr-queue output cos-map queue 1 threshold 3 4 5
mls qos srr-queue output cos-map queue 2 threshold 1 2
mls qos srr-queue output cos-map queue 2 threshold 2 3
mls qos srr-queue output cos-map queue 2 threshold 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 0
mls qos srr-queue output cos-map queue 4 threshold 3 1
mls qos srr-queue output dscp-map queue 1 threshold 3 32 33 40 41 42 43 44 45
mls qos srr-queue output dscp-map queue 1 threshold 3 46 47
mls qos srr-queue output dscp-map queue 2 threshold 1 16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 2 threshold 1 26 27 28 29 30 31 34 35
mls qos srr-queue output dscp-map queue 2 threshold 1 36 37 38 39
mls qos srr-queue output dscp-map queue 2 threshold 2 24
mls qos srr-queue output dscp-map queue 2 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3 0 1 2 3 4 5 6 7
mls qos srr-queue output dscp-map queue 4 threshold 1 8 9 11 13 15
mls qos srr-queue output dscp-map queue 4 threshold 2 10 12 14
mls qos queue-set output 1 threshold 1 100 100 50 200
mls qos queue-set output 1 threshold 2 125 125 100 400
mls qos queue-set output 1 threshold 3 100 100 100 400
mls qos queue-set output 1 threshold 4 60 150 50 200
mls qos queue-set output 1 buffers 15 25 40 20
mls qos
interface GigabitEthernet1/0/49
switchport mode trunk
switchport nonegotiate
srr-queue bandwidth share 1 30 35 5
priority-queue out
mls qos trust cos
auto qos trust
spanning-tree link-type point-to-point
channel-group 1 mode active
BRKCRS-2501.pdf (ciscolive.com)
check this link you will see all command you need
MHM
balaji.bandi
You can completely lift and shift the config, you need to move block by Block.
If i were you, i take new Cat 9300 connect console, bring the old configuration, do the basic configiration.
build block configuraiton, basic, routing, interface, QoS , security ( so keep pasting the configuraiton on cat 9300, what ever configuration not accepting, use document to find equivalent command and do the config on cat 9300 to fix)
After all when you do cut over - test and monitor is required, so you know all working as expected ,before you turn off Cat 2K switch from network.
some feature have moved as you mentioned OQS and some other stuff (you can find below URL)
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-3850-series-switches/118629-technote-qos-00.html
BB
