Need help with inter-vlan routing between hosts in different vlans
UserTM
Problem:
For a school project I have to configure a rather unconventional network. The original given topology was a bit simpler, but because we have to simulate the devices with EVE-NG we lost the ability to stack devices. So instead of stacking our Core and Distribution switches, we get the mess below.
I managed to get the layer 3 link-aggregation between the Core- and Distribution layer switches running and I also configured GLBP for all the Distribution Switches, but I'm still unable to ping between PCs in different VLANS. Pinging between PCs in the same VLAN seems to work just fine, even if they are connected to different access switches. The PCs are also able to ping to the virtual GLBP default gateway address of their respective VLAN. The Native VLAN is 1, and all the links between the Access and Distribution switches are in trunking mode. The Access switches' ports going to the PCs are configured in access mode for a specific VLAN. The Layer 3 Distribution switches are able to ping to the IPs of all the PCs regardless of their VLAN.
I have the feeling I'm missing something obvious, but I can't seem to find it.
I'm hoping that someone on this forum might be able to help me.
Let me now if you require further information in order to help me...
Topology:TopologyTopology
Running Configuration:
IP of DEVPC: 172.16.30.20 255.255.255.0 (gateway: 172.16.30.15)
IP of FINPC: 172.16.70.20 255.255.255.0 (gateway: 172.16.70.15)
Configuration of NYCore1
Spoiler
Building configuration...
Current configuration : 3764 bytes
! Last configuration change at 14:50:02 CET Fri May 11 2018
version 15.2
service compress-config
hostname NYCore1
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone CET 1 0
vtp domain NYVTP
vtp mode transparent
ip cef
ipv6 multicast rpf use-bgp
no ipv6 cef
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 10
 name GUEST
vlan 20
 name SALES
vlan 30
 name DEVELOPMENT
vlan 40
 name CODING
vlan 50
 name TESTING
vlan 60
 name SUPPORT
vlan 70
 name FINANCIAL
vlan 80
 name SHIPPING
vlan 90
 name MARKETING
vlan 99
 name MANAGEMENT
vlan 100
 name SERVER
vlan 110
 name EXTERNAL
interface Port-channel1
 no switchport
 ip address 172.16.1.9 255.255.255.252
interface Port-channel2
 no switchport
 ip address 172.16.1.13 255.255.255.252
interface Port-channel3
 no switchport
 ip address 172.16.1.17 255.255.255.252
interface Port-channel4
 no switchport
 ip address 172.16.1.21 255.255.255.252
interface Ethernet0/0
 no switchport
 no ip address
 duplex auto
 channel-protocol lacp
 channel-group 1 mode active
interface Ethernet0/1
 no switchport
 no ip address
 duplex auto
interface Ethernet0/2
 no switchport
 no ip address
 duplex auto
interface Ethernet0/3
 no switchport
 no ip address
 duplex auto
interface Ethernet1/0
 no switchport
 no ip address
 duplex auto
 channel-group 2 mode active
interface Ethernet1/1
 no switchport
 no ip address
 duplex auto
interface Ethernet1/2
 no switchport
 no ip address
 duplex auto
interface Ethernet1/3
 no switchport
 no ip address
 duplex auto
interface Ethernet2/0
 no switchport
 no ip address
 duplex auto
 channel-group 3 mode active
interface Ethernet2/1
 no switchport
 no ip address
 duplex auto
interface Ethernet2/2
 no switchport
 no ip address
 duplex auto
interface Ethernet2/3
 no switchport
 no ip address
 duplex auto
interface Ethernet3/0
 no switchport
 no ip address
 duplex auto
 channel-group 4 mode active
interface Ethernet3/1
 no switchport
 no ip address
 duplex auto
interface Ethernet3/2
 no switchport
 no ip address
 duplex auto
interface Ethernet3/3
 no switchport
 no ip address
 duplex auto
interface Ethernet4/0
interface Ethernet4/1
interface Ethernet4/2
interface Ethernet4/3
interface Ethernet5/0
interface Ethernet5/1
interface Ethernet5/2
 description connection to NYR1-e0/3
 no switchport
 ip address 172.16.1.2 255.255.255.252
 duplex auto
interface Ethernet5/3
router ospf 1
 network 172.16.1.0 0.0.0.3 area 0
 network 172.16.1.8 0.0.0.3 area 0
 network 172.16.1.12 0.0.0.3 area 0
 network 172.16.1.16 0.0.0.3 area 0
 network 172.16.1.20 0.0.0.3 area 0
 network 172.16.1.0 0.0.0.255 area 0
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
 logging synchronous
line aux 0
line vty 0 4
 login
end
Configuration of NYCore2
Spoiler
Current configuration : 3336 bytes
! Last configuration change at 14:51:01 CET Fri May 11 2018
version 15.2
hostname NYCore2
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
spanning-tree mode rapid-pvst
no switchport
ip address 172.16.1.25 255.255.255.252
no switchport
ip address 172.16.1.29 255.255.255.252
no switchport
ip address 172.16.1.33 255.255.255.252
no switchport
ip address 172.16.1.37 255.255.255.252
no switchport
no ip address
duplex auto
no switchport
no ip address
duplex auto
no switchport
no ip address
duplex auto
no switchport
no ip address
duplex auto
no switchport
no ip address
duplex auto
no switchport
no ip address
duplex auto
no switchport
no ip address
duplex auto
no switchport
no ip address
duplex auto
no switchport
no ip address
duplex auto
no switchport
no ip address
duplex auto
no switchport
no ip address
duplex auto
no switchport
no ip address
duplex auto
no switchport
no ip address
duplex auto
no switchport
no ip address
duplex auto
no switchport
no ip address
duplex auto
no switchport
no ip address
duplex auto
no switchport
ip address 172.16.1.6 255.255.255.252
duplex auto
router ospf 1
network 172.16.1.4 0.0.0.3 area 0
network 172.16.1.24 0.0.0.3 area 0
network 172.16.1.28 0.0.0.3 area 0
network 172.16.1.32 0.0.0.3 area 0
network 172.16.1.36 0.0.0.3 area 0
no ip http server
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
login
end
Configuration of NYDist1
Spoiler
Current configuration : 4888 bytes
! Last configuration change at 15:12:55 CET Fri May 11 2018
version 15.2
hostname NYDist1
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
 no switchport
 ip address 172.16.1.10 255.255.255.252
 no switchport
 ip address 172.16.1.38 255.255.255.252
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 switchport mode trunk
interface Vlan1
 ip address 172.16.1.41 255.255.255.248
 glbp 1 ip 172.16.1.45
interface Vlan10
 ip address 172.16.10.11 255.255.255.0
 glbp 10 ip 172.16.10.15
interface Vlan20
 ip address 172.16.20.11 255.255.255.0
 glbp 20 ip 172.16.20.15
interface Vlan30
 ip address 172.16.30.11 255.255.255.0
 glbp 30 ip 172.16.30.15
interface Vlan40
 ip address 172.16.40.11 255.255.255.0
 glbp 40 ip 172.16.40.15
interface Vlan50
 ip address 172.16.50.11 255.255.255.0
 glbp 50 ip 172.16.50.15
interface Vlan60
 ip address 172.16.60.11 255.255.255.0
 glbp 60 ip 172.16.60.15
interface Vlan70
 ip address 172.16.70.11 255.255.255.0
 glbp 70 ip 172.16.70.15
interface Vlan80
 ip address 172.16.80.11 255.255.255.0
 glbp 80 ip 172.16.80.15
interface Vlan90
 ip address 172.16.90.11 255.255.255.0
 glbp 90 ip 172.16.90.15
interface Vlan99
 ip address 172.16.99.11 255.255.255.0
 glbp 99 ip 172.16.99.15
interface Vlan100
 ip address 172.16.100.11 255.255.255.0
 glbp 100 ip 172.16.100.15
interface Vlan110
 ip address 172.16.110.11 255.255.255.0
 glbp 110 ip 172.16.110.15
router ospf 1
 network 172.16.1.40 0.0.0.7 area 0
 network 172.16.10.0 0.0.0.255 area 0
 network 172.16.20.0 0.0.0.255 area 0
 network 172.16.30.0 0.0.0.255 area 0
 network 172.16.40.0 0.0.0.255 area 0
 network 172.16.50.0 0.0.0.255 area 0
 network 172.16.60.0 0.0.0.255 area 0
 network 172.16.70.0 0.0.0.255 area 0
 network 172.16.80.0 0.0.0.255 area 0
 network 172.16.90.0 0.0.0.255 area 0
 network 172.16.99.0 0.0.0.255 area 0
 network 172.16.100.0 0.0.0.255 area 0
 network 172.16.110.0 0.0.0.255 area 0
no ip http server
ip route 0.0.0.0 0.0.0.0 172.16.1.9
ip route 0.0.0.0 0.0.0.0 172.16.1.37
control-plane
line con 0
 logging synchronous
line aux 0
line vty 0 4
 login
end
Configuration of NYDist2
Spoiler
Current configuration : 4303 bytes
! Last configuration change at 15:12:58 CET Fri May 11 2018
version 15.2
hostname NYDist2
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
 no switchport
 ip address 172.16.1.14 255.255.255.252
 no switchport
 ip address 172.16.1.34 255.255.255.252
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
interface Vlan1
 ip address 172.16.1.42 255.255.255.248
interface Vlan10
 ip address 172.16.10.12 255.255.255.0
interface Vlan20
 ip address 172.16.20.12 255.255.255.0
interface Vlan30
 ip address 172.16.30.12 255.255.255.0
interface Vlan40
 ip address 172.16.40.12 255.255.255.0
interface Vlan50
 ip address 172.16.50.12 255.255.255.0
interface Vlan60
 ip address 172.16.60.12 255.255.255.0
interface Vlan70
 ip address 172.16.70.12 255.255.255.0
interface Vlan80
 ip address 172.16.80.12 255.255.255.0
interface Vlan90
 ip address 172.16.90.12 255.255.255.0
interface Vlan99
 ip address 172.16.99.12 255.255.255.0
interface Vlan100
 ip address 172.16.100.12 255.255.255.0
interface Vlan110
 ip address 172.16.110.12 255.255.255.0
router ospf 1
no ip http server
ip route 0.0.0.0 0.0.0.0 172.16.1.13
ip route 0.0.0.0 0.0.0.0 172.16.1.33
control-plane
line con 0
 logging synchronous
line aux 0
line vty 0 4
 login
end
Configuration of NYDist3
Spoiler
Current configuration : 4869 bytes
! Last configuration change at 14:51:34 CET Fri May 11 2018
version 15.2
hostname NYDist3
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
 no switchport
 ip address 172.16.1.18 255.255.255.252
 no switchport
 ip address 172.16.1.30 255.255.255.252
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
interface Vlan1
 ip address 172.16.1.43 255.255.255.248
interface Vlan10
 ip address 172.16.10.13 255.255.255.0
interface Vlan20
 ip address 172.16.20.13 255.255.255.0
interface Vlan30
 ip address 172.16.30.13 255.255.255.0
interface Vlan40
 ip address 172.16.40.13 255.255.255.0
interface Vlan50
 ip address 172.16.50.13 255.255.255.0
interface Vlan60
 ip address 172.16.60.13 255.255.255.0
interface Vlan70
 ip address 172.16.70.13 255.255.255.0
interface Vlan80
 ip address 172.16.80.13 255.255.255.0
interface Vlan90
 ip address 172.16.90.13 255.255.255.0
interface Vlan99
 ip address 172.16.99.13 255.255.255.0
interface Vlan100
 ip address 172.16.100.13 255.255.255.0
interface Vlan110
 ip address 172.16.110.13 255.255.255.0
router ospf 1
no ip http server
ip route 0.0.0.0 0.0.0.0 172.16.1.17
ip route 0.0.0.0 0.0.0.0 172.16.1.29
control-plane
line con 0
 logging synchronous
line aux 0
line vty 0 4
 login
end
Configuration of NYDist4
Spoiler
! Last configuration change at 15:13:56 CET Fri May 11 2018
version 15.2
hostname NYDist4
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
 no switchport
 ip address 172.16.1.22 255.255.255.252
 no switchport
 ip address 172.16.1.26 255.255.255.252
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
interface Vlan1
 ip address 172.16.1.44 255.255.255.248
interface Vlan10
 ip address 172.16.10.14 255.255.255.0
interface Vlan20
 ip address 172.16.20.14 255.255.255.0
interface Vlan30
 ip address 172.16.30.14 255.255.255.0
interface Vlan40
 ip address 172.16.40.14 255.255.255.0
interface Vlan50
 ip address 172.16.50.14 255.255.255.0
interface Vlan60
 ip address 172.16.60.14 255.255.255.0
interface Vlan70
 ip address 172.16.70.14 255.255.255.0
interface Vlan80
 ip address 172.16.80.14 255.255.255.0
interface Vlan90
 ip address 172.16.90.14 255.255.255.0
interface Vlan99
 ip address 172.16.99.14 255.255.255.0
interface Vlan100
 ip address 172.16.100.14 255.255.255.0
interface Vlan110
 ip address 172.16.110.14 255.255.255.0
router ospf 1
no ip http server
ip route 0.0.0.0 0.0.0.0 172.16.1.21
ip route 0.0.0.0 0.0.0.0 172.16.1.25
control-plane
line con 0
 logging synchronous
line aux 0
line vty 0 4
 login
end
Configuration of NYASW1
Spoiler
Current configuration : 3212 bytes
! Last configuration change at 12:16:25 CET Fri May 11 2018
version 15.1
hostname NYASW1
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
 duplex auto
 duplex auto
 switchport access vlan 30
 switchport mode access
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 switchport access vlan 10
 duplex auto
 duplex auto
interface Ethernet6/0
 duplex auto
interface Ethernet6/1
 duplex auto
interface Ethernet6/2
 shutdown
 duplex auto
interface Ethernet6/3
 shutdown
 duplex auto
interface Vlan99
 ip address 172.16.99.21 255.255.255.0
ip default-gateway 172.16.99.15
no ip http server
control-plane
line con 0
 logging synchronous
line aux 0
line vty 0 4
 login
end
Configuration of NYASW5
Spoiler
Current configuration : 3113 bytes
! Last configuration change at 12:19:49 CET Fri May 11 2018
version 15.1
hostname NYASW5
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
 duplex auto
 duplex auto
 switchport access vlan 70
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 switchport access vlan 20
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 shutdown
 duplex auto
 shutdown
 duplex auto
interface Vlan99
 ip address 172.16.99.25 255.255.255.0
 shutdown
no ip http server
control-plane
line con 0
 logging synchronous
line aux 0
line vty 0 4
end
Good news, I finally managed to resolve the problem.
The cause was indeed a bug in the emulation software, I found the solution over here...
Basically I had to turn off Cisco Express Forwarding in order to get inter-vlan routing to work.
After issuing the no ip cef command on my Layer 3 Switches everything worked like it was supposed to.
A big thank you to Mohammed and Georg Pauwen for helping me along the way...
21 Replies 21
mohammed01701
Hi!
I think MAYBE you have problem with the routes- (both static and dynamic), you implemented static on NYDist1-3 that means everything routes to NYCore1 or NYCore2. Can you run "show ip route" on NYDist1, NYDist2 and NYDist3 and post it? I don´t understand why you don´t have any subnet under "router ospf 1" on NYDist3.
/Mohammed
Hi Mohammed,
You are correct to state that I shouldn"t have implemented static default routes on my Distribution Switches. (Instead I need to use the default-information originate command on my actual routers) However, while this is indeed a mistake, I don't believe it causes the issue of the inter-vlan routing since there are better matches for the IPs of the hosts in the routing table.
I deleted the static routes just to be sure and turned off all the core and distribution switches except NYDist1.
In theory I should still be able to route between vlans with only the blue devices in the topology above being active. (I'm hoping to pinpoint the problem by minimizing the area of possible failure)
The 2 DEVPCs are in the same VLAN (30/DEVELOPMENT) and are able to ping to eachother, they have an IP of 172.16.30.20 and 172.16.30.21 respectively with a default-gateway of 172.16.30.11 (I also turned glbp off) They are also able to ping their default gateways (172.16.30.11) and the other interface vlans on the NYDist1 switch (like 172.16.70.11 and 172.16.20.11), but I do get the following message when tracing the route (ICMP type:3, code:3, Destination port unreachable). Which I found strange, since I'm able to ping without any issues. I'm still unable to ping the FINPC (172.16.70.20 in VLAN 70/FINANCIAL) or the SALPC (172.16.20.20 in VLAN20/SALES) from the DEVPCs and vice versa.
Here is the routing table of Dist1:
Spoiler
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       a - application route
       + - replicated route, % - next hop override
Gateway of last resort is not set
      172.16.0.0/16 is variably subnetted, 30 subnets, 4 masks
C        172.16.1.8/30 is directly connected, Port-channel1
L        172.16.1.10/32 is directly connected, Port-channel1
C        172.16.1.36/30 is directly connected, Port-channel2
L        172.16.1.38/32 is directly connected, Port-channel2
C        172.16.1.40/29 is directly connected, Vlan1
L        172.16.1.41/32 is directly connected, Vlan1
C        172.16.10.0/24 is directly connected, Vlan10
L        172.16.10.11/32 is directly connected, Vlan10
C        172.16.20.0/24 is directly connected, Vlan20
L        172.16.20.11/32 is directly connected, Vlan20
C        172.16.30.0/24 is directly connected, Vlan30
L        172.16.30.11/32 is directly connected, Vlan30
C        172.16.40.0/24 is directly connected, Vlan40
L        172.16.40.11/32 is directly connected, Vlan40
C        172.16.50.0/24 is directly connected, Vlan50
L        172.16.50.11/32 is directly connected, Vlan50
C        172.16.60.0/24 is directly connected, Vlan60
L        172.16.60.11/32 is directly connected, Vlan60
C        172.16.70.0/24 is directly connected, Vlan70
L        172.16.70.11/32 is directly connected, Vlan70
C        172.16.80.0/24 is directly connected, Vlan80
L        172.16.80.11/32 is directly connected, Vlan80
C        172.16.90.0/24 is directly connected, Vlan90
L        172.16.90.11/32 is directly connected, Vlan90
C        172.16.99.0/24 is directly connected, Vlan99
L        172.16.99.11/32 is directly connected, Vlan99
C        172.16.100.0/24 is directly connected, Vlan100
L        172.16.100.11/32 is directly connected, Vlan100
C        172.16.110.0/24 is directly connected, Vlan110
L        172.16.110.11/32 is directly connected, Vlan110
Thanks in advance for your help,
UserTM
judging from the configs you posted, the inter-Vlan routing occurs on NYR1 and NYR2 ? Can you post the configuration of those two routers ?
Thanks for your reply,
I'm afraid the routers haven't been configured yet. The inter-vlan routing is supposed to take place on the Layer 3 switches (using SVIs). I wanted to get the internal VLAN connectivity working before worrying about Network Address Translation and external communication to the ISPs on the routers.
All the ports on the Core-switches are routed ports, and the ports in link-aggregation on the Distribution switches are routed ports as well, while the ports going to the access switches are all switchports in trunking mode.
I also added some more information about my problem in my reply to Mohammed, so if you're able to, you might want to read that reply as well.
Thanks in advance,
UserTM
I don't seem to see 'ip routing' enabled on any of the switches (or maybe I am overlooking something) ?
That's because show run doesn't show all the default configuration commands. When I issue show run all the ip routing command does appear in the running config. My routing table also isn't empty, so there's that.
something fundamental must be missing. What does your VTP look like, do you have a domain configured ?
Post the output of 'show ip route' from one of the distribution switches...
Hi!
If you want to see routing tabell on one of the NYDist, he or she posted before: see the previous post. Can post show ip arp on VLAN 20 and 70?
Can you shutdown the Links from NYSw5 to NYDist4, because of you are not configurated routing yet. When you shutdown those links i think you will see a diffrence. Please post show ip arp those vlans you do have a problem before you shutdown those links and arter!
How do you created vlans? I don't see any VLAN id and Names om the configuration you send yesterday
/Mohammed
My bad...got the routing table.
The problem might be with the GLBP...what is the output of 'show glbp 30' ?
Here is the output when only NYDist1 is turned on (I temporarily turned off the other Layer 3 switches to isolate the problem. Inter-vlan routing should be possible with just this one Layer 3 switch since both access switches have a link to Dist1)
NYDist1#show glbp vlan 30
Vlan30 - Group 30
  State is Active
    1 state change, last state change 00:52:30
  Virtual IP address is 172.16.30.15
  Hello time 3 sec, hold time 10 sec
    Next hello sent in 0.992 secs
  Redirect time 600 sec, forwarder timeout 14400 sec
  Preemption disabled
  Active is local
  Standby is unknown
  Priority 100 (default)
  Weighting 100 (default 100), thresholds: lower 1, upper 100
  Load balancing: round-robin
  Group members:
    aabb.cc80.7100 (172.16.30.11) local
  There is 1 forwarder (1 active)
  Forwarder 1
    State is Active
      1 state change, last state change 00:52:18
    MAC address is 0007.b400.1e01 (default)
    Owner ID is aabb.cc80.7100
    Redirection enabled
    Preemption enabled, min delay 30 sec
    Active is local, weighting 100
NYDist1#show glbp brief
Interface Grp Fwd Pri State Address Active router Standby router
Vl1 1 - 100 Active 172.16.1.45 local unknown
Vl1 1 1 - Active 0007.b400.0101 local -
Vl10 10 - 100 Active 172.16.10.15 local unknown
Vl10 10 1 - Active 0007.b400.0a01 local -
Vl20 20 - 100 Active 172.16.20.15 local unknown
Vl20 20 1 - Active 0007.b400.1401 local -
Vl30 30 - 100 Active 172.16.30.15 local unknown
Vl30 30 1 - Active 0007.b400.1e01 local -
Vl40 40 - 100 Active 172.16.40.15 local unknown
Vl40 40 1 - Active 0007.b400.2801 local -
Vl50 50 - 100 Active 172.16.50.15 local unknown
Vl50 50 1 - Active 0007.b400.3201 local -
Vl60 60 - 100 Active 172.16.60.15 local unknown
Vl60 60 1 - Active 0007.b400.3c01 local -
Vl70 70 - 100 Active 172.16.70.15 local unknown
Vl70 70 1 - Active 0007.b400.4601 local -
Vl80 80 - 100 Active 172.16.80.15 local unknown
Vl80 80 1 - Active 0007.b400.5001 local -
Vl90 90 - 100 Active 172.16.90.15 local unknown
Vl90 90 1 - Active 0007.b400.5a01 local -
Vl99 99 - 100 Active 172.16.99.15 local unknown
Vl99 99 1 - Active 0007.b400.6301 local -
Vl100 100 - 100 Active 172.16.100.15 local unknown
Vl100 100 1 - Active 0007.b400.6401 local -
Vl110 110 - 100 Active 172.16.110.15 local unknown
Vl110 110 1 - Active 0007.b400.6e01 local -
@mohammed01701 wrote:
Hi!
/Mohammed
I have already turned off all layer 3 switches except NYDist1, I do use VTP to propagate my VLANS, NYDist1 is the VTP-server of domain NYVTP (password is also NYVTP [Since this is just a simulation, I don't mind to share it, I probably change it later anyway]).
VLANs on NYDist1
Spoiler
NYDist1#show vtp status
VTP Version capable             : 1 to 3
VTP version running             : 1
VTP Domain Name                 : NYVTP
VTP Pruning Mode                : Disabled
VTP Traps Generation            : Disabled
Device ID                       : aabb.cc80.7100
Configuration last modified by 172.16.1.41 at 5-12-18 06:18:08
Local updater ID is 172.16.1.41 on interface Vl1 (lowest numbered VLAN interface found)
Feature VLAN:
VTP Operating Mode                : Server
Maximum VLANs supported locally   : 1005
Number of existing VLANs          : 17
Configuration Revision            : 5
MD5 digest                        : 0x84 0x2D 0xC1 0x32 0x11 0x20 0xB6 0x76
                                    0xB1 0x63 0x23 0x10 0xF2 0x40 0xD0 0x86
NYDist1#show vtp pass
NYDist1#show vtp password
VTP Password: NYVTP
NYDist1#show vlan
VLAN Name                             Status    Ports
1    default                          active
10   GUEST                            active
20   SALES                            active
30   DEVELOPMENT                      active
40   CODING                           active
50   TESTING                          active
60   SUPPORT                          active
70   FINANCIAL                        active
80   SHIPPING                         active
90   MARKETING                        active
99   MANAGEMENT                       active
100  SERVER                           active
110  EXTERNAL                         active
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
VLANs on NYASW1
Spoiler
NYASW1#show vtp status
Device ID                       : aabb.cc01.3100
Feature VLAN:
VTP Operating Mode                : Client
NYASW1#show vtp password
VTP Password: NYVTP
NYASW1#show vlan
1    default                          active
10   GUEST                            active    Et5/2, Et5/3, Et6/0, Et6/1
                                                Et6/2, Et6/3
20   SALES                            active
30   DEVELOPMENT                      active    Et0/2, Et0/3, Et1/0, Et1/1
                                                Et1/2, Et1/3, Et2/0, Et2/1
                                                Et2/2, Et2/3, Et3/0, Et3/1
                                                Et3/2, Et3/3, Et4/0, Et4/1
                                                Et4/2, Et4/3, Et5/0, Et5/1
40   CODING                           active
50   TESTING                          active
60   SUPPORT                          active
70   FINANCIAL                        active
80   SHIPPING                         active
90   MARKETING                        active
100  SERVER                           active
110  EXTERNAL                         active
VLANs on NYASW5
Spoiler
NYASW5#show vtp status
Device ID                       : aabb.cc01.7100
Feature VLAN:
NYASW5#show vtp password
VTP Password: NYVTP
NYASW5#show vlan
1    default                          active    Et6/2, Et6/3
20   SALES                            active    Et4/1, Et4/2, Et4/3, Et5/0
                                                Et5/1
40   CODING                           active
50   TESTING                          active
60   SUPPORT                          active
70   FINANCIAL                        active    Et0/2, Et0/3, Et1/0, Et1/1
                                                Et3/2, Et3/3, Et4/0
80   SHIPPING                         active
90   MARKETING                        active
100  SERVER                           active
110  EXTERNAL                         active
Hi!
As long every thing looks like fine:) But something has to bee wrong, i could not see any thing yet,  but please post those show commands, to figure out if there is any arps on PC on the difference vlans:
Can you post "show ip arp those vlans" you have a problem?
Can you post show spanning tree on those interfaces between Dist and Switchs?
Do you know which switch is root for spanning tree?
/Mohammed
Hi!
/Mohammed
Here you go,
NYDist1: show ip arp vlan 30 and 70
Spoiler
NYDist1#show ip arp vlan 30
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  172.16.30.11            -   aabb.cc80.7100  ARPA   Vlan30
Internet  172.16.30.15            -   0007.b400.1e01  ARPA   Vlan30
Internet  172.16.30.20           56   0050.7966.6825  ARPA   Vlan30
Internet  172.16.30.19           56   aabb.cc81.3100  ARPA   Vlan30
NYDist1#show ip arp vlan 70
Internet  172.16.70.11            -   aabb.cc80.7100  ARPA   Vlan70
Internet  172.16.70.15            -   0007.b400.4601  ARPA   Vlan70
Internet  172.16.70.20            0   0050.7966.6829  ARPA   Vlan70
On my access switches (Layer 2) I only have a vlan interface with an ip for my MANAGEMENT vlan 99, so I can't use the show ip arp vlan 30 or show ip arp vlan 70 command
NYASW1: show ip arp
Spoiler
NYASW1#show ip arp
Internet  172.16.99.11           61   aabb.cc80.7100  ARPA   Vlan99
Internet  172.16.99.15           61   0007.b400.6301  ARPA   Vlan99
Internet  172.16.99.21            -   aabb.cc81.3100  ARPA   Vlan99
NYASW5: show ip arp
Spoiler
NYASW5#show ip arp
Internet  172.16.99.11            0   aabb.cc80.7100  ARPA   Vlan99
Internet  172.16.99.15            0   0007.b400.6301  ARPA   Vlan99
Internet  172.16.99.25            -   aabb.cc81.7100  ARPA   Vlan99
Spanning tree (Im using pvst)
NYDist1 (link to NYASW1)
Spoiler
NYDist1#show spanning-tree interface ethernet 3/0
Vlan                Role Sts Cost      Prio.Nbr Type
VLAN0001            Desg FWD 100       128.13   Shr
VLAN0010            Desg FWD 100       128.13   Shr
VLAN0020            Desg FWD 100       128.13   Shr
VLAN0030            Desg FWD 100       128.13   Shr
VLAN0040            Desg FWD 100       128.13   Shr
VLAN0050            Desg FWD 100       128.13   Shr
VLAN0060            Desg FWD 100       128.13   Shr
VLAN0070            Desg FWD 100       128.13   Shr
VLAN0080            Desg FWD 100       128.13   Shr
VLAN0090            Desg FWD 100       128.13   Shr
VLAN0099            Desg FWD 100       128.13   Shr
VLAN0100            Desg FWD 100       128.13   Shr
VLAN0110            Desg FWD 100       128.13   Shr
NYDist1 (link to NYASW5)
Spoiler
NYDist1#show spanning-tree interface ethernet 5/0
VLAN0001            Desg FWD 100       128.21   Shr
VLAN0010            Desg FWD 100       128.21   Shr
VLAN0020            Desg FWD 100       128.21   Shr
VLAN0030            Desg FWD 100       128.21   Shr
VLAN0040            Desg FWD 100       128.21   Shr
VLAN0050            Desg FWD 100       128.21   Shr
VLAN0060            Desg FWD 100       128.21   Shr
VLAN0070            Desg FWD 100       128.21   Shr
VLAN0080            Desg FWD 100       128.21   Shr
VLAN0090            Desg FWD 100       128.21   Shr
VLAN0099            Desg FWD 100       128.21   Shr
VLAN0100            Desg FWD 100       128.21   Shr
VLAN0110            Desg FWD 100       128.21   Shr
NYASW1 (link to NYDist1)
Spoiler
NYASW1#show spanning-tree interface ethernet 0/0
VLAN0001            Root FWD 100       128.1    Shr
VLAN0010            Root FWD 100       128.1    Shr
VLAN0020            Root FWD 100       128.1    Shr
VLAN0030            Root FWD 100       128.1    Shr
VLAN0040            Root FWD 100       128.1    Shr
VLAN0050            Root FWD 100       128.1    Shr
VLAN0060            Root FWD 100       128.1    Shr
VLAN0070            Root FWD 100       128.1    Shr
VLAN0080            Root FWD 100       128.1    Shr
VLAN0090            Root FWD 100       128.1    Shr
VLAN0099            Root FWD 100       128.1    Shr
VLAN0100            Root FWD 100       128.1    Shr
VLAN0110            Root FWD 100       128.1    Shr
NYASW5 (link to NYDist1)
Spoiler
NYASW5#show spanning-tree interface ethernet 0/0
I just labbed this in GNS3, I agree with Mohammed, the configs look fine. Which switches are you using ? And which hosts/PCs ?
