Need help with inter-vlan routing between hosts in different vlans
UserTM
Problem:
For a school project I have to configure a rather unconventional network. The original given topology was a bit simpler, but because we have to simulate the devices with EVE-NG we lost the ability to stack devices. So instead of stacking our Core and Distribution switches, we get the mess below.
I managed to get the layer 3 link-aggregation between the Core- and Distribution layer switches running and I also configured GLBP for all the Distribution Switches, but I'm still unable to ping between PCs in different VLANS. Pinging between PCs in the same VLAN seems to work just fine, even if they are connected to different access switches. The PCs are also able to ping to the virtual GLBP default gateway address of their respective VLAN. The Native VLAN is 1, and all the links between the Access and Distribution switches are in trunking mode. The Access switches' ports going to the PCs are configured in access mode for a specific VLAN. The Layer 3 Distribution switches are able to ping to the IPs of all the PCs regardless of their VLAN.
I have the feeling I'm missing something obvious, but I can't seem to find it.
I'm hoping that someone on this forum might be able to help me.
Let me now if you require further information in order to help me...
Topology:TopologyTopology
Running Configuration:
IP of DEVPC: 172.16.30.20 255.255.255.0 (gateway: 172.16.30.15)
IP of FINPC: 172.16.70.20 255.255.255.0 (gateway: 172.16.70.15)
Configuration of NYCore1
Spoiler
Building configuration...
Current configuration : 3764 bytes
! Last configuration change at 14:50:02 CET Fri May 11 2018
version 15.2
service compress-config
hostname NYCore1
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone CET 1 0
vtp domain NYVTP
vtp mode transparent
ip cef
ipv6 multicast rpf use-bgp
no ipv6 cef
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 10
 name GUEST
vlan 20
 name SALES
vlan 30
 name DEVELOPMENT
vlan 40
 name CODING
vlan 50
 name TESTING
vlan 60
 name SUPPORT
vlan 70
 name FINANCIAL
vlan 80
 name SHIPPING
vlan 90
 name MARKETING
vlan 99
 name MANAGEMENT
vlan 100
 name SERVER
vlan 110
 name EXTERNAL
interface Port-channel1
 no switchport
 ip address 172.16.1.9 255.255.255.252
interface Port-channel2
 no switchport
 ip address 172.16.1.13 255.255.255.252
interface Port-channel3
 no switchport
 ip address 172.16.1.17 255.255.255.252
interface Port-channel4
 no switchport
 ip address 172.16.1.21 255.255.255.252
interface Ethernet0/0
 no switchport
 no ip address
 duplex auto
 channel-protocol lacp
 channel-group 1 mode active
interface Ethernet0/1
 no switchport
 no ip address
 duplex auto
interface Ethernet0/2
 no switchport
 no ip address
 duplex auto
interface Ethernet0/3
 no switchport
 no ip address
 duplex auto
interface Ethernet1/0
 no switchport
 no ip address
 duplex auto
 channel-group 2 mode active
interface Ethernet1/1
 no switchport
 no ip address
 duplex auto
interface Ethernet1/2
 no switchport
 no ip address
 duplex auto
interface Ethernet1/3
 no switchport
 no ip address
 duplex auto
interface Ethernet2/0
 no switchport
 no ip address
 duplex auto
 channel-group 3 mode active
interface Ethernet2/1
 no switchport
 no ip address
 duplex auto
interface Ethernet2/2
 no switchport
 no ip address
 duplex auto
interface Ethernet2/3
 no switchport
 no ip address
 duplex auto
interface Ethernet3/0
 no switchport
 no ip address
 duplex auto
 channel-group 4 mode active
interface Ethernet3/1
 no switchport
 no ip address
 duplex auto
interface Ethernet3/2
 no switchport
 no ip address
 duplex auto
interface Ethernet3/3
 no switchport
 no ip address
 duplex auto
interface Ethernet4/0
interface Ethernet4/1
interface Ethernet4/2
interface Ethernet4/3
interface Ethernet5/0
interface Ethernet5/1
interface Ethernet5/2
 description connection to NYR1-e0/3
 no switchport
 ip address 172.16.1.2 255.255.255.252
 duplex auto
interface Ethernet5/3
router ospf 1
 network 172.16.1.0 0.0.0.3 area 0
 network 172.16.1.8 0.0.0.3 area 0
 network 172.16.1.12 0.0.0.3 area 0
 network 172.16.1.16 0.0.0.3 area 0
 network 172.16.1.20 0.0.0.3 area 0
 network 172.16.1.0 0.0.0.255 area 0
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
 logging synchronous
line aux 0
line vty 0 4
 login
end
Configuration of NYCore2
Spoiler
Current configuration : 3336 bytes
! Last configuration change at 14:51:01 CET Fri May 11 2018
version 15.2
hostname NYCore2
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
spanning-tree mode rapid-pvst
no switchport
ip address 172.16.1.25 255.255.255.252
no switchport
ip address 172.16.1.29 255.255.255.252
no switchport
ip address 172.16.1.33 255.255.255.252
no switchport
ip address 172.16.1.37 255.255.255.252
no switchport
no ip address
duplex auto
no switchport
no ip address
duplex auto
no switchport
no ip address
duplex auto
no switchport
no ip address
duplex auto
no switchport
no ip address
duplex auto
no switchport
no ip address
duplex auto
no switchport
no ip address
duplex auto
no switchport
no ip address
duplex auto
no switchport
no ip address
duplex auto
no switchport
no ip address
duplex auto
no switchport
no ip address
duplex auto
no switchport
no ip address
duplex auto
no switchport
no ip address
duplex auto
no switchport
no ip address
duplex auto
no switchport
no ip address
duplex auto
no switchport
no ip address
duplex auto
no switchport
ip address 172.16.1.6 255.255.255.252
duplex auto
router ospf 1
network 172.16.1.4 0.0.0.3 area 0
network 172.16.1.24 0.0.0.3 area 0
network 172.16.1.28 0.0.0.3 area 0
network 172.16.1.32 0.0.0.3 area 0
network 172.16.1.36 0.0.0.3 area 0
no ip http server
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
login
end
Configuration of NYDist1
Spoiler
Current configuration : 4888 bytes
! Last configuration change at 15:12:55 CET Fri May 11 2018
version 15.2
hostname NYDist1
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
 no switchport
 ip address 172.16.1.10 255.255.255.252
 no switchport
 ip address 172.16.1.38 255.255.255.252
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 switchport mode trunk
interface Vlan1
 ip address 172.16.1.41 255.255.255.248
 glbp 1 ip 172.16.1.45
interface Vlan10
 ip address 172.16.10.11 255.255.255.0
 glbp 10 ip 172.16.10.15
interface Vlan20
 ip address 172.16.20.11 255.255.255.0
 glbp 20 ip 172.16.20.15
interface Vlan30
 ip address 172.16.30.11 255.255.255.0
 glbp 30 ip 172.16.30.15
interface Vlan40
 ip address 172.16.40.11 255.255.255.0
 glbp 40 ip 172.16.40.15
interface Vlan50
 ip address 172.16.50.11 255.255.255.0
 glbp 50 ip 172.16.50.15
interface Vlan60
 ip address 172.16.60.11 255.255.255.0
 glbp 60 ip 172.16.60.15
interface Vlan70
 ip address 172.16.70.11 255.255.255.0
 glbp 70 ip 172.16.70.15
interface Vlan80
 ip address 172.16.80.11 255.255.255.0
 glbp 80 ip 172.16.80.15
interface Vlan90
 ip address 172.16.90.11 255.255.255.0
 glbp 90 ip 172.16.90.15
interface Vlan99
 ip address 172.16.99.11 255.255.255.0
 glbp 99 ip 172.16.99.15
interface Vlan100
 ip address 172.16.100.11 255.255.255.0
 glbp 100 ip 172.16.100.15
interface Vlan110
 ip address 172.16.110.11 255.255.255.0
 glbp 110 ip 172.16.110.15
router ospf 1
 network 172.16.1.40 0.0.0.7 area 0
 network 172.16.10.0 0.0.0.255 area 0
 network 172.16.20.0 0.0.0.255 area 0
 network 172.16.30.0 0.0.0.255 area 0
 network 172.16.40.0 0.0.0.255 area 0
 network 172.16.50.0 0.0.0.255 area 0
 network 172.16.60.0 0.0.0.255 area 0
 network 172.16.70.0 0.0.0.255 area 0
 network 172.16.80.0 0.0.0.255 area 0
 network 172.16.90.0 0.0.0.255 area 0
 network 172.16.99.0 0.0.0.255 area 0
 network 172.16.100.0 0.0.0.255 area 0
 network 172.16.110.0 0.0.0.255 area 0
no ip http server
ip route 0.0.0.0 0.0.0.0 172.16.1.9
ip route 0.0.0.0 0.0.0.0 172.16.1.37
control-plane
line con 0
 logging synchronous
line aux 0
line vty 0 4
 login
end
Configuration of NYDist2
Spoiler
Current configuration : 4303 bytes
! Last configuration change at 15:12:58 CET Fri May 11 2018
version 15.2
hostname NYDist2
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
 no switchport
 ip address 172.16.1.14 255.255.255.252
 no switchport
 ip address 172.16.1.34 255.255.255.252
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
interface Vlan1
 ip address 172.16.1.42 255.255.255.248
interface Vlan10
 ip address 172.16.10.12 255.255.255.0
interface Vlan20
 ip address 172.16.20.12 255.255.255.0
interface Vlan30
 ip address 172.16.30.12 255.255.255.0
interface Vlan40
 ip address 172.16.40.12 255.255.255.0
interface Vlan50
 ip address 172.16.50.12 255.255.255.0
interface Vlan60
 ip address 172.16.60.12 255.255.255.0
interface Vlan70
 ip address 172.16.70.12 255.255.255.0
interface Vlan80
 ip address 172.16.80.12 255.255.255.0
interface Vlan90
 ip address 172.16.90.12 255.255.255.0
interface Vlan99
 ip address 172.16.99.12 255.255.255.0
interface Vlan100
 ip address 172.16.100.12 255.255.255.0
interface Vlan110
 ip address 172.16.110.12 255.255.255.0
router ospf 1
no ip http server
ip route 0.0.0.0 0.0.0.0 172.16.1.13
ip route 0.0.0.0 0.0.0.0 172.16.1.33
control-plane
line con 0
 logging synchronous
line aux 0
line vty 0 4
 login
end
Configuration of NYDist3
Spoiler
Current configuration : 4869 bytes
! Last configuration change at 14:51:34 CET Fri May 11 2018
version 15.2
hostname NYDist3
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
 no switchport
 ip address 172.16.1.18 255.255.255.252
 no switchport
 ip address 172.16.1.30 255.255.255.252
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
interface Vlan1
 ip address 172.16.1.43 255.255.255.248
interface Vlan10
 ip address 172.16.10.13 255.255.255.0
interface Vlan20
 ip address 172.16.20.13 255.255.255.0
interface Vlan30
 ip address 172.16.30.13 255.255.255.0
interface Vlan40
 ip address 172.16.40.13 255.255.255.0
interface Vlan50
 ip address 172.16.50.13 255.255.255.0
interface Vlan60
 ip address 172.16.60.13 255.255.255.0
interface Vlan70
 ip address 172.16.70.13 255.255.255.0
interface Vlan80
 ip address 172.16.80.13 255.255.255.0
interface Vlan90
 ip address 172.16.90.13 255.255.255.0
interface Vlan99
 ip address 172.16.99.13 255.255.255.0
interface Vlan100
 ip address 172.16.100.13 255.255.255.0
interface Vlan110
 ip address 172.16.110.13 255.255.255.0
router ospf 1
no ip http server
ip route 0.0.0.0 0.0.0.0 172.16.1.17
ip route 0.0.0.0 0.0.0.0 172.16.1.29
control-plane
line con 0
 logging synchronous
line aux 0
line vty 0 4
 login
end
Configuration of NYDist4
Spoiler
! Last configuration change at 15:13:56 CET Fri May 11 2018
version 15.2
hostname NYDist4
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
 no switchport
 ip address 172.16.1.22 255.255.255.252
 no switchport
 ip address 172.16.1.26 255.255.255.252
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
 no switchport
 no ip address
 duplex auto
interface Vlan1
 ip address 172.16.1.44 255.255.255.248
interface Vlan10
 ip address 172.16.10.14 255.255.255.0
interface Vlan20
 ip address 172.16.20.14 255.255.255.0
interface Vlan30
 ip address 172.16.30.14 255.255.255.0
interface Vlan40
 ip address 172.16.40.14 255.255.255.0
interface Vlan50
 ip address 172.16.50.14 255.255.255.0
interface Vlan60
 ip address 172.16.60.14 255.255.255.0
interface Vlan70
 ip address 172.16.70.14 255.255.255.0
interface Vlan80
 ip address 172.16.80.14 255.255.255.0
interface Vlan90
 ip address 172.16.90.14 255.255.255.0
interface Vlan99
 ip address 172.16.99.14 255.255.255.0
interface Vlan100
 ip address 172.16.100.14 255.255.255.0
interface Vlan110
 ip address 172.16.110.14 255.255.255.0
router ospf 1
no ip http server
ip route 0.0.0.0 0.0.0.0 172.16.1.21
ip route 0.0.0.0 0.0.0.0 172.16.1.25
control-plane
line con 0
 logging synchronous
line aux 0
line vty 0 4
 login
end
Configuration of NYASW1
Spoiler
Current configuration : 3212 bytes
! Last configuration change at 12:16:25 CET Fri May 11 2018
version 15.1
hostname NYASW1
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
 duplex auto
 duplex auto
 switchport access vlan 30
 switchport mode access
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 switchport access vlan 10
 duplex auto
 duplex auto
interface Ethernet6/0
 duplex auto
interface Ethernet6/1
 duplex auto
interface Ethernet6/2
 shutdown
 duplex auto
interface Ethernet6/3
 shutdown
 duplex auto
interface Vlan99
 ip address 172.16.99.21 255.255.255.0
ip default-gateway 172.16.99.15
no ip http server
control-plane
line con 0
 logging synchronous
line aux 0
line vty 0 4
 login
end
Configuration of NYASW5
Spoiler
Current configuration : 3113 bytes
! Last configuration change at 12:19:49 CET Fri May 11 2018
version 15.1
hostname NYASW5
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
 duplex auto
 duplex auto
 switchport access vlan 70
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 switchport access vlan 20
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 duplex auto
 shutdown
 duplex auto
 shutdown
 duplex auto
interface Vlan99
 ip address 172.16.99.25 255.255.255.0
 shutdown
no ip http server
control-plane
line con 0
 logging synchronous
line aux 0
line vty 0 4
end
21 Replies 21
Hi!
I just need to add some few question:
Can you do a ping from NYASWS5 (not the PC, i mean from the switch) to 20-DEVPC?
Can you post show ip route on the NYASWS1 and 5, MAYBE you do have a routing function on those Access switchs and there could be a problem?
/Mohammed
@mohammed01701 wrote:
Hi!
/Mohammed
I can't ping from the NY Access Switches (VLAN 99) to the DEVPCs or any of the other VLANS either.
Here is the routing table of NYASW1:
NYASW1#show ip route
Default gateway is 172.16.99.15
Host               Gateway           Last Use    Total Uses  Interface
ICMP redirect cache is empty
And NYASW5:
NYASW5#show ip route
And NYDist1 again:
Spoiler
NYDist1#show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       a - application route
       + - replicated route, % - next hop override
Gateway of last resort is not set
      172.16.0.0/16 is variably subnetted, 30 subnets, 4 masks
C        172.16.1.8/30 is directly connected, Port-channel1
L        172.16.1.10/32 is directly connected, Port-channel1
C        172.16.1.36/30 is directly connected, Port-channel2
L        172.16.1.38/32 is directly connected, Port-channel2
C        172.16.1.40/29 is directly connected, Vlan1
L        172.16.1.41/32 is directly connected, Vlan1
C        172.16.10.0/24 is directly connected, Vlan10
L        172.16.10.11/32 is directly connected, Vlan10
C        172.16.20.0/24 is directly connected, Vlan20
L        172.16.20.11/32 is directly connected, Vlan20
C        172.16.30.0/24 is directly connected, Vlan30
L        172.16.30.11/32 is directly connected, Vlan30
C        172.16.40.0/24 is directly connected, Vlan40
L        172.16.40.11/32 is directly connected, Vlan40
C        172.16.50.0/24 is directly connected, Vlan50
L        172.16.50.11/32 is directly connected, Vlan50
C        172.16.60.0/24 is directly connected, Vlan60
L        172.16.60.11/32 is directly connected, Vlan60
C        172.16.70.0/24 is directly connected, Vlan70
L        172.16.70.11/32 is directly connected, Vlan70
C        172.16.80.0/24 is directly connected, Vlan80
L        172.16.80.11/32 is directly connected, Vlan80
C        172.16.90.0/24 is directly connected, Vlan90
L        172.16.90.11/32 is directly connected, Vlan90
C        172.16.99.0/24 is directly connected, Vlan99
L        172.16.99.11/32 is directly connected, Vlan99
C        172.16.100.0/24 is directly connected, Vlan100
L        172.16.100.11/32 is directly connected, Vlan100
C        172.16.110.0/24 is directly connected, Vlan110
L        172.16.110.11/32 is directly connected, Vlan110
Hi!
If you move 15FINPC to same switch "NYSW1 or NYSW2" on 20-DEVPC
 and see if there is problem when they both PC connected same access switch,
Another test, Connect both PC on the NYDist1 and see if it works, if that is not working, create a loopback address and give same ip range on FIN subnet, and use that looback some a source to ping 20-DEVPC, i think you will see on those tests if a problem on the pc or you do have anothe problem:
Everything looks fine. MAYBE the problem is the emulator.... Do some test and see if it works when you have only loopbacks, or loopback one vlan subnet other pc and so on...
/Mohammed
@Georg Pauwen wrote:
I just labbed this in GNS3, I agree with Mohammed, the configs look fine. Which switches are you using ? And which hosts/PCs ?
I'm using the network emulation software called EVE-NG. I'm no expert, but from what I understand they are running Cisco IOS images on Linux Servers in a cluster hosted at my University College.
This is the first year we're using the software, my predecessors had to make everything in Packet Tracer. (To be honest, I wish I could use that instead)
These are the IOU/IOL images I'm using:
  • i86bi-linux-l2-adventerprise-M-15.1-20140814.bin (access switches)
  • i86bi-linux-l2-adventerprisek9-15.2d.bin (distribution/core switches)
As for the PCs, they are Virtual PCs,  I only get a limited amount of network related options when I connect to them. (https://sourceforge.net/projects/vpcs/) My problem could be an issue in the emulation software, but I doubt it. Inter-vlan routing should be possible according to EVE-NG's website. I'm planning to ask my professor's help if I can't resolve the issue on my own next week.
Good news, I finally managed to resolve the problem.
The cause was indeed a bug in the emulation software, I found the solution over here...
Basically I had to turn off Cisco Express Forwarding in order to get inter-vlan routing to work.
After issuing the no ip cef command on my Layer 3 Switches everything worked like it was supposed to.
A big thank you to Mohammed and Georg Pauwen for helping me along the way...
glad you got it resolved. I wasn't aware you were using an emulator...which one do you have ? It doesn't look like GNS3 or Packet Tracer...
Thanks again for your help, the software I'm using is called EVE-NG. I refer to my earlier quote below for more details if you're interested.
