C4500-x not supporting GLC-T SFP
Chala
My cisco C4500-x switch is not supporting GLC-T SFP transciever. the iOS version of the switch is (cat4500e -UNIVERSALK9-M), Version 03.08.01.E. I check the compatablity of the SFP with the switch and found out the iOS version is too old to support the SFP.
Is it really the ios version problem? if yes, how do I upgrade it ?
@Chala
do
boot system flash bootflash:/<YOU-FILE-NAME-WITH-EXTENSION>
Best regards
43 Replies 43
@Chala hi, what is exact model of your switch? can you share the '#Sh run' output. now 3.11.x series is the recommended OS version but depends on the exact model. also use below tool to see the compatibility.
https://tmgmatrix.cisco.com/
GLC-T is End of support now. replacement is GLC-TE
Good luck
KB
Chala
Switch Model WS-C4500X-32SFP+
M02@rt37
Hello @Chala
It should be the IOS version. Check the compatibility matrix of your C4500 with your exact IOS version. And check the minimum IOS to support SFP GLC-T(E).
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-4000-series-switches/27848-179.html
https://www.rogerperkin.co.uk/cisco/switching/4500x/how-to-upgrade-ios-on-cisco-4500x-switch/
Best regards
Already checked it and it's not compatable.
 the supported iOS Version is 03.08.11.E and above.
Could you tell me the upgrading process?
@Chala
What is your exact model please ?
Best regards
Model No : WS-C4500X-32SFP+
Thanks @Chala
Upgrade to Release 3.11.10E MD
https://software.cisco.com/download/home/284275051/type/282046477/release/3.11.10E
Best regards
Thanks for your advice.
Can I upgrade directly the iOS to 3.11.10E MD or should I do it sequentially ?
thanks!
@Chala
Whats is your ROMmon version please ?
Best regards
Please help here.
Switch#show rom-monitor
% This command is not supported on this platform.
thanks!
@Chala  You should have this information with the command #show version
Share this output.
Best regards
WhatsApp Image 2024-11-06 at 16.36.13_d815f4be.jpgWhatsApp Image 2024-11-06 at 16.36.48_4b7dcfaa.jpg
Direct upgrade to 3.11.11 is supported.
NOTE:
1.  Limitations due to ROMMON version incompatibility has been removed.
2.  I've just upgraded a Sup7E, from 3.8.3, to 3.11.11 without an issue.
Thanks @Leo Laohoo  for that feedback.
Best regards
