Need (Network devices config monitoring software)
Imran Ahmad
Level 2
Level 2
Can anyone help me on what monitoring tool i should use to monitor and keep logs of any configuration changes happens to my Cisco network devices (including- ISRs, FWs..)
Thanks for your advice
5 Replies 5
Reza Sharifi
I use SolarWinds.  It works pretty well.
http://www.solarwinds.com/
Thatnks Jerry and Reza.
Just to make clear , Is that SolarWinds Orion or SolarWinds Network-Monitoring Tool ?
Imran,
The package is called Solarwinds Orion.  You then add/buy whatever modules you need.
So in this case, you need the NPM module (Network Performance Monitoring).
http://www.solarwinds.com/InternalSearch/Search/Index/?q=NPM&c=ProductNPM
Jerry Paul
Solarwinds is best tool for monitoring configurations on Cisco Equipment.
