Need solution for odd recurring event of users interconnecting two switchports
____x____
After taking a new job and over the course 10 months I have seen an unusual thing happen.  I have had users interconnect two data ports on the same switch 3 times. This occurs at the main campus and brings the entire network to it's knees, which I didn't think could happen.  All the ports are configure portfast. Should I remove the portfast?  What is the best/easiest way to prevent this from nuking the network again?
the best option would obviously be to keep users from physical access to the switches. If that is not possible, you could try and implement some sort of authentication. What is the typical configuration of an access port now ?
--> I have had users interconnect two data ports on the same switch 3 times.
What do the users actually do, connect two ports on the same switch to a hub ?
Seb Rupik
Hi there,
It is best practice to enable BPDU Guard on access ports. On each access switchport add the following:
spanning-tree bpduguard enable
This will place the switchprort in a err-disabled state (requiring a shut/ no shut to bring it back up) when ever it receives a BPDU, ie when it is connected to another switch, or itself.
cheers,
Seb.
Seb Rupik response is the best, HOWEVER, BPDU Guard is of no use if someone has (secretly) enabled "auto-recovery" of error-disabled ports.
Another thing, if you're new to the job, don't enable BPDU Guard without permission.
Joseph W. Doherty
Disabling portfast should preclude a L2 loop, but of course you lose the benefits of using portfast. (BTW, what variant of STP are you using?)
You could try Seb's suggestion. That would be easy and might be enough.
Your devices might have additional features to further limit and/or mitigate someone spanning two ports, like unicast flooding limits, etc.
You mention the "... brings the entire network to it's knees ...", which makes me wonder about your L2 design (perhaps a L2 redesign would limit the impact area).
