SYN Attack Mitigation
Moneta82
Frequent Visitor
Frequent Visitor
Hi guys,
As per my understanding a good way to protect an internal network from a syn attack ( not directed to the switch / router ) to another network client on the same subnet is using tcp intercept.
What can I do if on my switches ( 9300 / 2960-XR ) if that function is not available? If I well understood CoPP is only for packet handled by switch CPU not for packet directed to another device on the net.
2 Accepted Solutions
Internal expect to be trusted network, and all the devices are maintained with Antivirus - you have good perimeter FW which blocks any malicious content coming into your devices.
If any device has compromised internally, you need to have control and notification of visibility.
this can only be possible kind of product available in the network like IDS/ IPS / Stealth watch. to get a notification.
BB
If the attacks are internal and if you have monitoring devices in place, you should be able to see the amount of traffic from a particular user to a particular internal server, you than need to have your security people notify the person and to make him/her stop doing that.
Reza Sharifi
tcp syn attack can not protected by CoPP.  For DDoS prevention and mitigation, you can talk to your service provider or talk to 3rd party cloud based solution like Akamai. Usually the service provider can redirect your traffic to their site, mitigate the DDOS and than send you the clean traffic. Service provider solutions are usually much cheaper than using 3rd party vendors.
Hi Sharifi,
I forgot to say that I'm trying to block this kind of attack on an internal network by an internal attacker prior reaching any firewall interface.
BB
