12-07-2016 01:36 AM - edited 03-08-2019 08:28 AM
Find attached the questions
For some reason it is blocked when I put it here and marked as spam.
12-07-2016 07:30 PM
Did you try issuing the 'auto qos voip trust' in interface configuration mode : switch (config-if)#?
If that does not work, pls post exact model and software version of old and new switches?
Thx
MS
12-08-2016 12:19 AM
First of all thanks for your answer,
Wen I configure the Interfaces in config-if , all goes well except the 'auto qos voip trust' entry.
The entries about qos are in the beginning of our template and set like: see attached.
12-08-2016 06:11 PM
Based on the below link, the command is available.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/software/release/15-0_2_ez/command/reference/cr2960/cli1.html
Try removing any QOS config and add again.
hth
MS
