Need suggestion on WS-C3650-24TD-S uplink port
Tarun Vyas
We are having EOL WS-C3560G-24TS-S switch and looking suggestion to purchase a new device. I have suggested a WS-C3650-24TD-S latest device.
WS-C3650-24TD-S
Fixed Uplinks : 2 x 10 Gigabit Ethernet with SFP+ and 2 x 1 Gigabit Ethernet with SFP
Note : The SFP+ interface supports both 10 Gigabit Ethernet and Gigabit Ethernet ports.
I have big confusion on its fixed uplinks description.
1) As it has given Gigabit Ethernet port.
Confusion : Can I use only ethernet module (GLC-T) or I can use fiber SFP module (1000BaseSX SFP) also on all of four uplinks.
2) Can I use all four port with 1 Gig module
3) When I am using 10 Gig uplinks in SFP+ port at same time can I use remaining 2 port as 1 Gig uplink.
I have referred below link from cisco to understand the things but still I am not clear.
https://www.cisco.com/c/en_in/products/collateral/switches/catalyst-3650-series-switches/datasheet-c78-729449.html
5 Replies 5
Reza Sharifi
See table-1 in this link:
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3650-series-switches/datasheet-c78-729449.html
It depends which model you get.  For example:
If you get "WS-C3650-24TS" this comes with only 4 1Gig and no 10Gig
If you get "WS-C3650-24TD" this comes with 2 10Gig and 2 1Gig
if you get "WS-C3650-48TQ" this comes with 4 10Gig or 4 1Gig
for 1Gig you use SFP and for 10Gig you use SFP+
GLC-T is only compatible with 1Gig ports.
BTW, the 3650 series switches are good switches.
Predrag Jovic
Level 3
Level 3
1) You can mix GLC-T, GLC-SX-MMD, GLC-SX-MM, GLC-LH-SMD, GLC-LH-SM
2) Yes
3) According to Table 1 and Table 2 on page Cisco Catalyst 3650 Series Switches Data Sheet can be used 2 x 10 Gigabit Ethernet with SFP+ and 2 x 1 Gigabit Ethernet with SFP at the same time.
Philip D'Ath
The 9000 series switches replaced the 3650 series.  You should probably be looking at a 9300:
https://www.cisco.com/c/en/us/products/switches/catalyst-9300-series-switches/index.html
Yes that switch is fine for 4x1GB see chart below , just requires sfp no extra commands
http://www.cisco.com/c/en/us/products/switches/catalyst-3650-series-switches/models-comparison.html#4x
2 x 10 Gigabit Ethernet with SFP+ (or 4 x Gigabit Ethernet with SFP) Uplinks
Models Total 10/100/1000 Ethernet Ports Default AC Power Supply Available PoE Power
WS-C3650-24TD 24 250 WAC -
WS-C3650-48TD 48 250 WAC -
