need terminology
mikecoles
I didn't believe it until I saw no route or default gateway in the "show run" on a 3750.
I have fumbled through search because I don't what the correct terminology is.
We have an odd setup and I'm sre that contributes to what I'm seeing.
We have a 3750 which is plugged into a generic switch. The management IP address on the switch is attached to VLAN1 (192.168.4.14/24) IOS version is 12.2(20)SE4
My workstation is plugged into a different generic switch. My ip address is 10.17.12.45/24. My default gateway is 10.17.12.1. My OS is SuSE 9.3
Both of the generic switches are plugged into a thrid generic switch
MY_WS <-> GS2 <-> GS3 <-> GS1 <-> 3750
I am able to telnet to the 3750, ping it, etc.
How am I able to do this w/o there being a route/gateway on the 3750? A Cisco guy I was talking w/ said it was because the switch had heard traffic coming from my workstation and already knew what my MAC was.
I had thought that if the 3750 and the workstation were on different subnets (by address, not 'wire-wise'), they would have to go through a router.
When I remove the default gw from my workstation, communcication stops. This would lead me to believe that this is something special w/ Cisco.
Could someone further explain this?
Thank you,
Mike Coles
5 Replies 5
paddyxdoyle
Level 6
Level 6
Mike,
I'm not sure how the 3750 learns the gateway either but it IS a feature of the 3750 so your are correct in your findings.
I have looked this up previously on Cisco and although the documentation confirmed the 3750 can detect the default gateway, it didn't say how....must be magic!
Rgds
PJD
Paddy,
Thanks for the verification. It's helped my sanity.
I've run across IRDP and proxy-arp. Both of which could possibly have been the culprit, except for the fact they'e both disabled.
Good research project for a Friday.
Mike Coles
Mike
It would be interesting and possibly useful to see the output of show ip route on the 3750. Could you do it and post the output?
And it would be helpful to know how the 3750 is configured - especially how the vlan interface is configured. Could you post that?
I can think of a couple of explanations that might fit what you experienced. It certainly looks like your end station and the 3750 are in the same broadcast domain so physically their frames would get to each other. If your end station would ARP for the address of the 3750, the ARP request would certainly get to the 3750 and it would respond and they would talk to each other. The fact that communications stops when you remove your default gateway indicates that this is probably not the correct explanation for your symptoms.
The other thing that occurs to me has to do with your default gateway. Your post gave the address of your gateway but did not indicate whether the gateway is present in the network or not. If it is present it might be that you forward to the gateway and it might have logic that would forward to the 3750. If your gateway is physically not present in the network then I would think about proxy arp on the 3750. I know you said it was disabled but it sure sounds like a proxy arp behavior.
One other possibility also occurs to me. Most IP stacks will send a gratiutous ARP when the interface comes up (it is frequently part of the logic of checking for duplicate addresses). Is it possible that your end station and the 3750 learned each others IP to MAC mapping through the effects of gratiutous ARP?
Rick
Rick
Rick,
Info from the switch listed below. As for the gateway for the workstation, it is up. All equipment is in the same broadcast domain. ARP traffic is blown around the network freely. (Our campus is basically one big vlan. Yep, I know.) I could see them learning of each other's MAC addresses, but they don't show up in each other's tables.
#show ip route
Default gateway is not set
Host Gateway Last Use Total Uses Interface
ICMP redirect cache is empty
#sh run
Current configuration : 5185 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
switch 1 provision ws-c3750g-24ts
switch 2 provision ws-c3750g-24ts
ip subnet-zero
ip dhcp ping packets 0
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface GigabitEthernet1/0/1
description uplink
spanning-tree portfast
interface GigabitEthernet1/0/2
description user
interface GigabitEthernet1/0/3
description user
interface GigabitEthernet1/0/4
description user
interface GigabitEthernet1/0/5
description user
interface GigabitEthernet1/0/6
description user
interface GigabitEthernet2/0/27
description SFP
interface GigabitEthernet2/0/28
description SFP
interface Vlan1
description Main Uplink!!
ip address 192.168.4.14 255.255.255.0
no ip proxy-arp
no ip route-cache
ip classless
no ip http server
control-plane
monitor session 2 source vlan 1
monitor session 2 destination interface Gi1/0/2
end
#show ip int vlan1
Vlan1 is up, line protocol is up
Internet address is 192.168.4.14/24
Broadcast address is 255.255.255.255
Address determined by setup command
MTU is 1500 bytes
Helper address is not set
Directed broadcast forwarding is disabled
Outgoing access list is not set
Inbound access list is not set
Proxy ARP is disabled
Local Proxy ARP is disabled
Security level is default
Split horizon is enabled
ICMP redirects are always sent
ICMP unreachables are always sent
ICMP mask replies are never sent
IP fast switching is disabled
IP fast switching on the same interface is disabled
IP Flow switching is disabled
IP CEF switching is disabled
IP Fast switching turbo vector
IP multicast fast switching is disabled
IP multicast distributed fast switching is disabled
IP route-cache flags are None
Router Discovery is disabled
IP output packet accounting is disabled
IP access violation accounting is disabled
TCP/IP header compression is disabled
RTP/IP header compression is disabled
Probe proxy name replies are disabled
Policy routing is disabled
Network address translation is disabled
WCCP Redirect outbound is disabled
WCCP Redirect inbound is disabled
WCCP Redirect exclude is disabled
BGP Policy Mapping is disabled
#sh mac-address-table | include fa7e
(fa7e is part of my workstation's mac)
On my workstation, the only MAC's that show in the table are for my gateway (10.17.12.1), and a printer on the same network (10.17.12.44)
I didn't design the network, so I don't have all the answers as to why settings are the way they are. I would try to dig up the answers the best as I can if anyone needs more info. (Such as why `ip dhcp ping packets 0` is set.)
Thanks for taking the time to look at this.
Mike Coles
Mike
Thanks for the additional information. It does reinforce what you had said about proxy arp being disabled and about having no default gateway on the 3750. I am a bit surprised that the show ip route is entirely empty. I would have expected to see at least a route for 192.168.4.0
Especially having seen this I believe as you said that they are not communicating directly (which was my first theory). So now I am assuming that your workstation must be forwarding to its default gateway. I must then assume that the default gateway must be forwarding to the 3750. Does the default gateway device for your workstation (10.17.12.1) happen to also have an address in 192.168.4.0? Does the default gateway device have a default route?
Rick
Rick
