what does fastethernet4/0/1 mean?
axfalk
On the 7206 router network diagram, it shows fastethernet int as slot 4 port 1. However, on the config, it's defined as fastethernet4/0/1. Does anybody happen to know what that middle 0 stands for?
thanks.
ankurbhasin
Level 9
Level 9
Hi axfalk,
Depending on the type of router you have , the port designation convention might change. For example, some high end routers such as 7500 series device can have a virtual interface processor. Designation of these ports would also include the VIP slot:
Taking your example of fastethernet 4/0/1
port type ===> fast ethernet
slot num ===> 4
port adap number ===> 0
port number ===> 1
Ankur
