Need to add Bash commands
Mr.Kumar
I want to add the following Bash commands on a Nexus switch. Will there be any impact from adding them?
Switch(config)# feature bash-shell
Switch(config)# end
Switch # run bash
bash-4.4$ cd /mnt/pstore/stats_ssd
bash-4.4$ ls -ll
Thanks in Advance
@Mr.Kumar just by enabling the feature itself does not normally cause any disruption to your network services / data plane forwarding. It's a control plane operation.
One thing to be aware of, is the power this can give. The shell can give you a deeper level of control over the switch than the standard NX-OS CLI can. and so If an unauthorised user does gain access and has the necessary privileges, the could cause some real harm to your network/device and services.
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
