Need to do PAT/NAT on Outside interface of ASA with the below requirement
nasum5245
Hi Everyone,
I need some help from you people in the below requirement configuration in ASA.
I have an ASA deployed with inside and outside interfaces configured.
>> When users access the Outside interface of ASA ( https://20.1.1.3:443 ) with port 443 ASA should do a PAT/NAP and forward the traffic to the internal resource https://10.1.1.10:443
>> When users access the same outside interface of ASA ( https://10.1.1.3:444 ) with port 444 it should forward the traffic to https://10.1.1.11:443
>> All the traffic is based on https alone but need to achieve this with custom ports.
Help me if this use case is possible with ASA and if yes, kindly help me with the configuration.
Thanks and Regards
amikat
Provided your ASA outside interface IP address is 20.1.1.3 you can try to configure as per beneath:
object network HOST_1
host 10.0.0.10
nat (inside,outside) static interface service tcp 443 443
object network HOST_2
host 10.0.0.11
nat (inside,outside) static interface service tcp 443 444
access-list inbound permit tcp any object HOST_1 eq 443
access-list inbound permit tcp any object HOST_2 eq 443
access-group inbound in interface outside
Best regards,
Antonin
