Need to know regarding port channel configuration
EPHRAIM MANI
Level 3
Level 3
Need to know regarding port channel configuration, if the member interface is update with the VLAN add command/prunning will the Port-channel interface go down ?
Glenn Matthys
Port-channels exhibit the same behaviour as individual interfaces.
Peter Paluch
If you modify the configuration of a physical member in an Etherchannel bundle, this physical interface may be suspended and temporarily removed from the bundle if its configuration is not identical or compatible with the configuration of the Port-channel interface.
As a matter of rule, after physical ports are bundled into an Etherchannel, all further configuration shall be performed on the Port-channel interface only, and not on physical interfaces anymore.
Best regards,
Peter
