need to know sfp compatibility with another vendor
baselzind
Level 6
Level 6
I have a cisco sfp (SFP-10G-SR) and i need to connect it to  a DELL sfp (SFP-10G-SR) part number is WTRD1. are they compatible with each other? the dell sfp has the attached info
12 Replies 12
balaji.bandi
as per standard that should work - this can only be confirmed once connected and tested.
if you have both the sides optic available, you need to test.  (my past experience it works with other vendor with 10G-SR)
BB
problem is I need to confirm first in order to buy the cisco sfp as i dont have it.  is there some kind of method to tell if two sfp can work with each other ? for example the wave length matching?
as i mentioned It works as expected, if you have more concern you can buy both side cisco 10G-SR SFP Optic to meet the requirement.
BB
marce1000
  - In essence the question 'doesn't matter' , the only thing  that counts is that the fiber-mode must be the same at both ends (and or both ends can then use their own-branded sfp's accordingly).
 M.
baselzind
Level 6
Level 6
If i want to buy the cisco SFP-10G-SR , is this the part model that i ask the seller to purchase "SFP-10G-SR" or there is some other part model name?
 - For your cisco devices enter the switch-model (e.g.) here : https://tmgmatrix.cisco.com/ , you will then find the full model names of the compatible sfp's (too).
 M.
baselzind
Level 6
Level 6
No I'm asking what should i tell the my purchasing people to buy is it simply cisco SFP-10G-SR or there is a specific part number for this sfp?
Leo Laohoo
The optics are fine.
I want to know what platform is the Cisco side connected on.
cisco WS-C3850-24P with C3850-NM-2-10G module
What firmware and what is the uptime.
baselzind
Level 6
Level 6
regarding the mmf cable that i need to get for this sfp , does any OM work or it need to be a certain OM?
 - Ref : https://www.cisco.com/c/en/us/products/collateral/interfaces-modules/transceiver-modules/data_sheet_c78-455693.html
 M.
