Need to Re-Address a Site SEQUENCE of steps ?
MKCHAURASIA
I need to Re-address a site New Ip add for router interface, server, printer and adding a new subnet to site replacing a older subnet with bigger subnet which is already in production what should be my sequence of steps that I should follow if some thing goes wrong I can quickly revert back to old config and other precautions if any ?
sanmigueelbeer
For router interface, use the "ip address x.x.x.x y.y.y.y SECONDARY". It also pays to put a loopback IP Address (subnet mask of /32) too.
For the rest, unless you want a static IP Address, you can create a new DHCP scope on your DHCP server.
