need to upgrade cisco 3560G switch ios
Dragomir
I need to upgrade my cisco 3560G 8 port poe switch .
any idea how to do this?
also which one do i choose to use?
10 Replies 10
balaji.bandi
Please confirm is this an old 3560G 8 or a new While color 3560C?
what is the current version running?  It going to end of Live May 2021
if old : good  IOS i still stick with -  12.2.55-SE12 MD
https://software.cisco.com/download/home/282526415/type/280805680/release/12.2.55-SE12
check below models and confirm which one :
OLD
https://www.cisco.com/c/en/us/support/switches/catalyst-3560-series-switches/series.html
New :
https://www.cisco.com/c/en/us/products/switches/catalyst-3560-c-series-switches/index.html
BB
Hello
  1. Copy the new xxx.bin file to a usb drive
  2. Check to see if you have space for the new software -
    show flash:
    show version  < this will show you the existing file information
    show boot
  3. install usb drive
    copy usb:xxxx.bin flash:
    verify /md5 flash:xxxx.bin
  4. conf t
    no boot
    boot system flash:xxxxx.bin  <new .bin file)
    exit
  5. wr mem
  6. reload
Kind Regards
Paul
The switch is https://www.cisco.com/c/en/us/support/switches/catalyst-3560cg-8pc-s-compact-switch/model.html
3560-CG- port POE switch
sh ver shows this
c3560cg-home#sh ver
Cisco IOS Software, C3560C Software (C3560c405ex-UNIVERSALK9-M), Version 15.2(2)E7, RELEASE SOFTWARE (fc3)
Hello
Then select the
universalk9-mz.152-2.e10.bin file
Kind Regards
Paul
What is the reason for the upgrade? make sure you read the release notes and understand the bugs and caveats.
The latest Gold is  15.2.2E10 MD
https://software.cisco.com/download/home/283733640/type/280805680/release/15.2.2E10?i=!pp
release notes and upgrade process in the document.
https://www.cisco.com/c/en/us/support/ios-nx-os-software/ios-15-2e/products-release-notes-list.html
BB
@Dragomir  wrote:
Then select the universalk9-mz.152-2.e10.bin file
WTF.  No!
Do NOT "upgrade" the firmware using the BIN file.  NO!
If you do not know what you are doing, ALWAYS download the TAR file.  Use the following command to PROPERLY extract the files:
archive download-sw usbflash0:IOS_filename.tar
That is it.  No need to "check the MD5" or "copy this to there".  Do that command and the script will do everything for you.
Never (ever!) use the BIN file unless you know exactly how to fix stuff when the BIN file breaks!
Thank you very much. I managed to upgrade successfully following your method.
谢谢你。如果想升级后缀.Tar的 用他的方法能成功,但是比较慢 要等待很久
感谢,按照你的方法升级成功了。Thank you very much. I managed to upgrade successfully following your method.
cabajo1969
Hello, I'm connecting to this old discussion; I need help to find the correct fw to update my CATALYST C3560G (WS-C3560G-24PS-S). The command sh ver shows:
Cisco IOS Software, C3560 Software (C3560-IPBASE-M), Version 12.2(35)SE5, RELEASE SOFTWARE (fc1)
 What should I upload? The model is an old blue one (not white). Thanks a lot for help.
