Needing Assistance with Network Scheme involving 1 router and 2 switches.
marclungi
I have an issue with my current network that I am working on.  I am  studying to achieve my CCNA and have ran into a problem.  In my network  scheme, I have 1 1841 Cisco Router that is directed connected to two  2950 Cisco Switches.  These switches are directly connected to hosts.
My  problem is I cannot get the hosts on one end to connect to the hosts on  the other end of the network.  I have attempted to create a VLAN  structure but have ran into an issue here because my router does not  accept VTP information so the switches cannot pass VTP info.
Can someone give me any insight as to what I am doing incorrect or what path I need to take?
I have also attached my .PKT file from Packet Tracer Version 5.1
2 Accepted Solutions
Bilal Nawaz
Hello Marc,
VTP information can not be passed through the router. The requirement for this to work is a layer 2. i.e. your switches need to be connected to each other. It seems like you're trying to route between VLAN's and also do VTP at the same time.
I'll try to go through this in a easy way so you can understand what is required. This is bare minimal config for you to get end to end connectivity, so please don't mind if I take any existing configuration out. (Attached will be my version of the PKT file so you can see) There are two versions to this.
  1. Without VTP (Just router that is routing between subnets)
  2. With VTP - everything will need to change in terms of the topology
We'll start with option 1 - on R1. Your overall config seems fine, however I do want to mention that in a 'router on a stick' scenario you don't normally assign an IP to the physical interfaces themselves, you only assign active IP addresses on the Sub interfaces:
e.g. instead of this:
interface FastEthernet0/1
ip address 192.168.30.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1.2
encapsulation dot1Q 2
ip address 192.168.20.5 255.255.255.0
you do not need the address on fa0/1 you can just specify the sub interfaces address as you have done correctly for int Fa0/1.2
Since all of your PC's are in VLAN 2 we'll just have this:
no ip address
duplex auto
speed auto
Subsequent to this I have removed the VLAN interfaces on the switch as they aren't serving any purpose interms of routing. However you can assign the SVI's back if you wish.
I also did the same for vlan 3 (your servers)
I noticed you are running EIGRP? You only have one router here so EIGRP isn't required. Your router knows about all subnets since they are connected subnets. And it will route between subnets if necessary.
Your default gateway was also misconfigured on the finance and web servers.
I have split this out so that all Servers are on VLAN 3
All PC's are in VLAN 2
All clients and servers have the default gateway of the local router's interface address. And the router is doing the routing between subnets.
No VTP is operational.
If you would like me to go through the VTP side of it, please tell me which PC's and servers should be in which VLAN. And only then I will be able to try and show you the difference between these.
Hope this helps
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Hello
The can  use the router for the communication between the switches and hosts.
router
int fa0/0
no shut
int fa0/0.10
Description Vlan 10
encap dot1.q 10
ip address 10.10.10.254 255.255.255.0
int fa0/0.20
Descritop  vlan 20
encap dot1.q 10
ip address 20.20.20.254 255.255.255.0
Switch1:
conf  t
vlan10,20
exit
int vlan 10
ip address 10.10.10.1 255.255.255.0
int x/x
switchport trunk encp dot1
switch mode trunk
no shut
int fax/x
description access port for host
switchport-access vlan 10
switchport host
no shut
ip default-gateway 10.10.10.254
Switch2:
conf  t
vlan10,20
exit
int vlan 20
ip address 20.20.20.1 255.255.255.0
int x/x
switchporttrunk encp dot1
switch mode trunk
no shut
int fax/x
switchport-access vlan 20
switchporthost
no shut
ip default-gateway 20.20.20.254
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
Bilal Nawaz
Hello Marc,
duplex auto
speed auto
no ip address
duplex auto
speed auto
Hope this helps
Just thought I should do the VTP version too just so we can see the difference.
Here is the topology change that I was talking about in my previous post. Note that to get VTP to work we have to connect the switches together.
VTP packets are sent in either Inter-Switch Link (ISL) frames or in IEEE 802.1Q (dot1q) frames. Therefore the router could not 'carry' this for us like switches do. Its not like the role that the 'transparent mode' that switches can be.
SW1#show vtp status
VTP Version                     : 2
Configuration Revision          : 0
Maximum VLANs supported locally : 255
Number of existing VLANs        : 7
VTP Operating Mode              : Server
VTP Domain Name                 : lungi
VTP Pruning Mode                : Disabled
VTP V2 Mode                     : Disabled
VTP Traps Generation            : Disabled
MD5 digest                      : 0x9A 0xE3 0x0A 0xC6 0x2B 0xB7 0x85 0x18
Configuration last modified by 192.168.20.4 at 3-1-93 02:29:35
Local updater ID is 0.0.0.0 (no valid interface found)
Switch#show vtp status
VTP Version                     : 2
VTP Operating Mode              : Client
Router configuration:
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.2
interface FastEthernet0/0.3
encapsulation dot1Q 3
ip address 172.16.10.5 255.255.255.0
The switches are not doing any routing and layer 3 is serving no purpose. hence I have left them out again. But you can include this in the configuration if you wish for things like telnet/SSH/TFTP access etc...
Example on how to configure VTP and more info here:
http://www.cisco.com/en/US/tech/tk389/tk689/technologies_configuration_example09186a0080890607.shtml
http://www.cisco.com/en/US/tech/tk389/tk689/technologies_tech_note09186a0080094c52.shtml
Hope this helps
Hello
router
int fa0/0
no shut
int fa0/0.10
Description Vlan 10
encap dot1.q 10
int fa0/0.20
Descritop  vlan 20
encap dot1.q 10
Switch1:
conf  t
vlan10,20
exit
int vlan 10
int x/x
switch mode trunk
no shut
int fax/x
switchport host
no shut
Switch2:
conf  t
vlan10,20
exit
int vlan 20
int x/x
switch mode trunk
no shut
int fax/x
switchporthost
no shut
Thanks.
Kind Regards
Paul
