Neflow configuration on Port-Channel
athemistocleous
Do we have to configured the following commands on the physical interfaces of a port-channel or on the port-channel will be enough:
ip flow ingress
ip route-cache flow
thanks
Andreas
Richard Burts
Andreas
You do not have to configure NetFlow on the physical interfaces. It is sufficient to configure it on the logical interface where the IP address is configured.
Rick
Rick
