neighbors
vishalpatil86
hi,
which is the command for displaying neighbors other than cisco devices??
Hi Vishal,
Are you looking for a command similar to show cdp neighbor?
I used the next method to define a device that is connected to a router.
I run the show arp command.
Then I locate the MAC address of the IP attached to the connected device which I am looking for.
Lets assume that the MAC is 13:44:3A:34:24:1B
The first three bytes correspond to the OUI address and is unique for every device.
Then you can use the next link to find the type of a device, could be e.g. a Dell server etc
http://www.coffer.com/mac_find/
Hope that helps!
Vasilis
Hi Vishal,
you could use the show lldp command. It is the kind of works like cdp, but on non Cisco devices. No give it a try.
Try this link out
http://www.cisco.com/en/US/docs/ios/cether/configuration/guide/ce_lldp-med.html
Cheers
Rustom Billimoria
LLDP will only work if the other devices are setup to use it.  I don't think I have seen anywhere yet that actually uses it .
I use a lot of HP switches and other vendor equipment. Just like cisco has cdp enabled by default, they too have it enabled. I might be wrong, but in the long run, its worth a shot. Besides Cisco too has lldp enabled on most devices by default.
Rustom Billimoria
CCIE R&S# 24798
Sent from my BlackBerry® smartphone from Tata Indicom
