no ip vrf command on Cisco 881
I have a Cisco 881 router with  c880data-universalk9-mz.150-1.M7 IOS.
I can not issue the ip vrf  command.
From which version of IOS this command is available?
5 Replies 5
vmiller
Level 7
Level 7
Accrding to my pass at feature navigator, its not available for that platform. I searched on mpls vpn cli for IPv4 /IPv6.
I search on Multi-VRF Support (VRF-Lite).
881 plataform with c880data-universalk9-mz.150-1.M7 IOS supports this feature.
When I issue ip ? command I get
Global IP configuration subcommands:
  access-list           Named access-list
  accounting-list       Select hosts for which IP accounting information is
                        kept
  accounting-threshold  Sets the maximum number of accounting entries
  accounting-transits   Sets the maximum number of transit entries
  address-pool          Specify default IP address pooling mechanism
  admission             Network Admission Control (NAC)
  alias                 Alias an IP address to a TCP port
  arp                   IP ARP global configuration
  auth-proxy            Authentication Proxy
  bootp                 Config BOOTP services
  cef                   Cisco Express Forwarding
  classless             Follow classless routing forwarding rules
  ddns                  Configure dynamic DNS
  default-gateway       Specify default gateway (if not routing IP)
  default-network       Flags networks as candidates for default routes
  device                Device tracking
  dhcp                  Configure DHCP server and relay parameters
  dhcp-client           Configure parameters for DHCP client operation
  dhcp-server           Specify target DHCP server parameters
  dns                   Configure DNS server for a zone
  domain                IP DNS Resolver
  domain-list           Domain name to complete unqualified host names.
  domain-lookup         Enable IP Domain Name System hostname translation
  domain-name           Define the default domain name
  finger                finger server
  flow-aggregation      Configure flow aggregation
  flow-cache            Configure netflow cache parameters
  flow-capture          Capture additional netflow information
  flow-egress           Configure netflow egress
  flow-export           Specify host/port to send flow statistics
  flow-top-talkers      Configure netflow top talkers
  forward-protocol      Controls forwarding of physical and directed IP
                        broadcasts
  ftp                   FTP configuration commands
  gratuitous-arps       Generate gratuitous ARPs for PPP/SLIP peer addresses
  host                  Add an entry to the ip hostname table
  host-list             Configure a host list
  host-routing          Enable host-based routing (proxy ARP and redirect)
  hostname              Configure hostname types
  hp-host               Enable the HP proxy probe service
  http                  HTTP server configuration
  icmp                  ICMP options
  inspect               Context-based Access Control Engine
  local                 Specify local options
  mfib                  Multicast Forwarding
  mroute                Configure static multicast routes
  msdp                  MSDP global commands
  multicast             Global IP Multicast Commands
  multicast-routing     Enable IP multicast forwarding
  name-server           Specify address of name server to use
  nat                   NAT configuration commands
  nbar                  NBAR - Network Based Application Recognition
  options               IP Options treatment
  port-map              Port to application mapping (PAM) configuration
                        commands
  prefix-list           Build a prefix list
  radius                RADIUS configuration commands
  rcmd                  Rcmd commands
  reflexive-list        Reflexive access list
  route                 Establish static routes
  routing               Enable IP routing
  sap                   Global IP Multicast SAP Commands
  scp                   Scp commands
  sctp                  Global SCTP parameters
  security              Specify system wide security information
  sla                   IP Service Level Agreement
  source-route          Process packets with source routing header options
  ssh                   Configure ssh options
  subnet-zero           Allow 'subnet zero' subnets
  tacacs                TACACS configuration commands
  tcp                   Global TCP parameters
  telnet                Specify telnet options
  tftp                  tftp configuration commands
  traffic-export        IP traffic export configuration commands
  verify                URPF SNMP trap and IP packet header validation command
Hello
880 series supports a single universal image with Cisco Software Activation.  The active feature set is determined by the software
license installed on the platform.
In this case, VRF Lite is only supported when the Adv. IP feature license is installed.
Router#show license
Index 1 Feature: advipservices
        Period left: Life time
        License Type: Permanent
        License State: Active, In Use
        License Count: Non-Counted
        License Priority: Medium
Sush
I will verifiy the active licenses
Thanks!
