Nesus 9k with commad "logging trap < severity No>"
Bill lo
At traditional switch / Router , if i want  the trap server to receive specific syslog,
i can use gloabel command : logging trap Warning
But at Nexus Switch (N9504), I cant use this feature by this command~
I will appreciate if someone can help me out.
Thanks!
There is this command:
logging server x.x.x.x 4 facility syslog
Reza Sharifi
Warning is severity 4
so, you could do something like this
logging monitor [ severity-level ]
see table 8-1
and config examples:
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/5_x/nx-os/system_management/configuration/guide/sm_nx_os_cg/sm_5syslog.html#71793
Hi Reza ,
Thank you for your reply, But....
I think this set of commands:
terminal monitor
is use in "device to log messages by their severity level to console sessions."
And what i need is "log trap" send to specific server [by this command"logging host <Server_IP>"]
whith specified severity level or higher
