Switching
Labels
Welcome to the Cisco Community Ask Me Anything conversation. Submit your questions from Monday, February 2, 2026, through Friday, February 20, 2026. Our colleagues Amruta Navadagi, Anaya Kalawat, and Mohammad Mehtabuddin will be waiting to assist you...
amnavada by • Cisco Employee
  • 14558 Views
  • 29 replies
  • 1 Helpful votes
Important alertsMS130-24(P) switches will reboot twice during the upgrade process when transitioning to MS 18.1.8 (or later) from MS 18.1.7 or earlier. This behavior is expected, and is not indicative of a problem.New feature highlightsGroup Policy A...
Raphael_L by • Meraki Community All-Star
  • 760 Views
  • 7 replies
  • 1 Helpful votes
I bought a Cisco Catalyst switch from a hamfest (amateur radio swap meet) and am trying to get it working.  I am a retired software engineer and am just looking to get this working.  I can connect to it through a serial conection and can run some ini...
Hi,few month ago 17.15.5 turned to be the recommended IOS-XE version and now with these vulnaibility there should be an upgrade from it. what do you recommend and advise? 17.18.4, 17.15.6 or anything ?https://sec.cloudapps.cisco.com/security/center/c...
Hi Cisco Community,I would like to clarify the StackWise compatibility between the original T3 stacking hardware and the newer T3A hardware for the Cisco Catalyst C9300L-24P-4G.We currently have both of the following stacking kits available:STACK-KIT...
Jenson106 by • Community Member
  • 141 Views
  • 1 replies
I know this is an older thread but I get the following when trying to enable this guestshell. Any ideas? #guestshell enableInterface will be selected if configured in app-hostingPlease wait for completion% Error: No interface configuration for guests...
MFLauder by • Level 1
  • 120 Views
  • 1 replies
I'm looking for Cisco Letter of Volatility for this Cisco 48-Port Network Switch Part # C9200L-48PL-4G-E. This Cisco Letter of Volatility will include all the Volatile Memory, Non-Volatile Memory, Media and how to properly sanitize and erase the memo...
Samer3310 by • Community Member
  • 142 Views
  • 1 replies
Hi alli could do with some advice, we need to use MFA when logging into our Cisco switches. We currently use windows radius.ive tried setting up duo but cant get it to work, also tried the entra ID plugin on the windows radius server, that also fails...
Dears , hello i wanna ask a question about auto smart port when i am trying to apply auto smart port to switch the port to trunk and i give  commands like IP dhcp snooping trust and no authentication port-control auto   inside the a user-defined macr...
afifimo1996 by • Community Member
  • 322 Views
  • 5 replies
Is there any thought being put into updating the emails that are sent for ACL updates? They are currently worthless. It dumps everything into one big block so there is no way to know what was actually updated in the ACL list without extra digging. It...
LukeA123 by • Community Member
  • 119 Views
  • 2 replies
