netflow 6509
acazarkov
Level 3
Level 3
Hi ,
I'm trying to setup PTRG network tool for monitoring my cat6509 . But my configuration will not work properly. On PRTG I can see the statistics for one vlan. So far I have not worked with netflow if someone can help me with this
My configuracion is :
Ip flow-cache timeout active 1
ip flow ingress layer2-switched vlan 2,7,49
multilink bundle-name both
mls ip multicast flow-stat-timer 9
mls aging long 64
mls aging normal 64
no mls flow ip
no mls flow ipv6
mls nde sender version 5
mls qos
no mls acl tcam share-global
mls cef error action freeze
mls cef maximum-routes ip 239
interface GigabitEthernet1/47  /on this inteface is PRTG
 switchport
 switchport access vlan 7
 switchport mode access
 no ip address
 flowcontrol send on
interface Vlan2
 ip address
 no ip redirects
 ip flow ingress
 ip route-cache flow
interface Vlan7
 ip address 192.168.1.254 255.255.255.0
 no ip redirects
 ip flow ingress
 ip route-cache flow
interface Vlan49
 ip address 10.101.10.10 255.255.255.0
 no ip proxy-arp
 ip flow ingress
 ip route-cache flow
ip flow-export source GigabitEthernet3/1  /my link to ISP
ip flow-export version 5
ip flow-export destination 192.168.1.1 255.255.255.0 9996
ip flow-aggregation cache protocol-port
 cache entries 1024
 cache timeout inactive 300
 export destination 192.168.1.1 9996
 enabled
rizwanr74
Level 11
Level 11
Hi there,
this is all you needed.
ip route-cache flow
mls aging long 64
mls aging normal 32
mls flow ip interface-full
ip flow-export source Vlan49
ip flow-export destination 192.168.1.1 9996
ip flow ingress layer2-switched vlan x, y, z (separate each desired VLAN with a comma)
ip flow ingress
Hope this helps.
Rizwan Rafeek.
Thanks for reply .
does not understand why the PTRG only shows the flow of 1M in the VLAN ,when have traffic from 800M.
show version:
IOS (tm) s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-M), Version 12.2(18)SXF11, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Fri 14-Sep-07 21:50 by kellythw
Image text-base: 0x40101040, data-base: 0x42DC0AF0
ROM: System Bootstrap, Version 12.2(17r)SX5, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-M), Version 12.2(18)SXF11, RELEASE SOFTWARE (fc1)
sh ip flow export
Flow export v5 is enabled for main cache
  Exporting flows to  192.168.1.1 (9996)
  Exporting using source interface Vlan49
  Version 5 flow records
  Cache for protocol-port aggregation:
  91352593 flows exported in 2990908 udp datagrams
  0 flows failed due to lack of export packet
  0 export packets were sent up to process level
  0 export packets were dropped due to no fib
  0 export packets were dropped due to adjacency issues
  0 export packets were dropped due to fragmentation failures
  0 export packets were dropped due to encapsulation fixup failures
  0 export packets were dropped enqueuing for the RP
  0 export packets were dropped due to IPC rate limiting
  0 export packets were dropped due to Card not being able to export
did you remove your config lines and copy what I posted for you?
ip flow-cache timeout active 1
mls aging long 64
mls aging normal 64
no mls flow ip
no mls flow ipv6
mls qos
ip flow-export source 49
