netflow and ip flow top talker in cisco 3560 switch-ios 15
hi ,
                 i am faiz ,i want to netflow in my cisco 3560 switch and ip flow top talker but i did configure netflow and ip flow top talker but its not working.
plz how to configre netflow to give inforation to my netflow manager and ip flow top talker .
        thank you
Switch Ports Model              SW Version            SW Image
*    1 30    WS-C3560X-24       15.0(2)SE1            C3560E-UNIVERSALK9-M
thanks for reply,
   i have heard that netflow support on latest ios version on 3560-x
Agree,
I mis-read your post - did not notice you pointed HW version to be 3560-X.
This is detail config guide for it:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750x_3560x/software/release/15.0_2_se/configuration/guide/swmnetflow.html
Can you elaborate on  what are your current configs and what exactly not working ?
Nik
HTH,
Niko
this is my configuration but no result,
MY REQUIRMENT IS I HAVE A TWO CISCO 3560 SWITCH WHICH IS RUNNING HSRP AND EIGRP
I need a all vlan 1 devices and users ,if they go to anyware out of lan to interface g1/4 ,they should have a record.
i can able to ping my netflow server and all units getting but except it
Current configuration : 5693 bytes
! Last configuration change at 12:15:59 UTC Thu Jun 13 2013
! NVRAM config last updated at 12:16:00 UTC Thu Jun 13 2013
version 15.0
no service pad
hostname 3560-X-TATA
boot-start-marker
boot-end-marker
enable secret 5 $1$noPD$12H1OP44QVk6Aj9E7jxbB0
username cisco privilege 15 password 0 cisc
no aaa new-model
clock timezone UTC 5 30
system mtu routing 1500
flow record lab1
match datalink dot1q priority
match datalink mac source-address
match datalink mac destination-address
match ipv4 tos
match ipv4 protocol
match ipv4 destination address
match transport source-port
match transport destination-port
collect interface input snmp
collect interface output snmp
collect counter flows
collect counter bytes
collect counter packets
collect timestamp sys-uptime first
collect timestamp sys-uptime last
flow exporter netflowserver
description corpor@teserver
destination 10.10.17.166
source Vlan1
dscp 3
transport udp 9996
flow monitor FLOW-MONITOR-1
record lab1
cache timeout active 300
ip routing
interface GigabitEthernet1/4
description COPD_TATA_100MPBS
no switchport
ip flow ingress
ip flow egress
ip flow monitor FLOW-MONITOR-1 input
ip address 192.168.2.14 255.255.255.252
interface Vlan1
ip flow ingress
ip flow egress
ip address 10.10.50.53 255.255.252.0
standby 10 ip 10.10.50.51
standby 10 priority 200
standby 10 preempt
standby 10 track 1 decrement 150
router eigrp 500
network 10.10.48.0 0.0.3.255
network 192.168.2.12 0.0.0.3
eigrp stub connected summary
ip default-gateway 10.10.50.52
ip http server
ip http secure-server
ip flow-export source Vlan1
ip flow-export destination 10.10.17.166 9996
ip route 0.0.0.0 0.0.0.0 192.168.2.13
snmp-server community public RO
snmp-server community netflow RW
snmp ifmib ifindex persist
end
3560-X-TATA#show flow record
flow record lab1:
  Description:        User defined
  No. of users:       1
  Total field space:  51 bytes
  Fields:
    match ipv4 tos
    match ipv4 protocol
3560-X-TATA#show flow monitor FLOW-MONITOR-1
Flow Monitor FLOW-MONITOR-1:
  Flow Record:       lab1
  Flow Exporter:     netflowserver
  Cache:
    Type:              normal
    Status:            allocated
    Size:              128 entries / 9732 bytes
  Cache:
    Type:              normal (Platform cache)
    Status:            allocated
  Timers:
                       Local        Global
    Inactive Timeout:  15 secs
    Active Timeout:    300 secs     1800 secs
    Update Timeout:    1800 secs
