Re: CCNA Technical Lab Setup requirement
virgoboy009
Level 3
Level 3
I would like to know how many router and switches would be required to completely practise the CCNA Lab.
KA.
Thanks for your posts!
I guess to do Frame-Relay we would require 3 routers ?
Also which hardware i would need to simulate ISDN .
Please confirm.
KA.
Hi KA,
For frame relay lab you can use router acting as frame relay switch to have complete set for frame relay, check out the below link to the same :-
http://www.ciscopress.com/articles/article.asp?p=170741&seqNum=7
and for ISDN setup i would suggest rather going with physical hardware try with packet tracers or with simulators.
Hope to help !!
Ganesh.H
Remember to rate the helpful post
5 Replies 5
Use the Packet Tracer 5.2 and you'll be fine.
Federico.
I used 3 routers and 2 switches and it was more than enogh. I would say 2 routers and 2 switches are enough but if you want more complicate scenarios then get more than that.
Please confirm.
KA.
Please confirm.
KA.
Hi KA,
Hope to help !!
Ganesh.H
Are you going to do the latest CCNA? ISDN is no longer a topic.
Federico.
