netflow configration 15.1
amit bhatnagar
I was trying to configure netflow on  6509 with image 15.1 but I dont find syntax can someone please advise command sets for netflow config
10 Replies 10
thanks for reply Sandeep but none of the document provides information about confguring netflow on IOS 15.0 versions , I hope I am not missing anything
HI Amit,
last post also have a link which supports netflow config for 15 ios.
http://www.plixer.com/blog/flexible-netflow/how-to-configure-cisco-6500-sup2t-netflow/
http://www.plixer.com/blog/cisco-netflow/catalyst-6509-netflow-support/
The source documentation for configuring Flexible NetFlow on IOS 15.0SY can be found here:
http://www.cisco.com/en/US/docs/ios-xml/ios/fnetflow/configuration/15-0sy/fnf-15-0sy-book.html
thansk for quick reply sandeep ,
On my 6509 it doesnt give option to configure netflow . Output is below . IOS is 15.1(1)SY1
6509(config)#ip flow?
% Unrecognized command
use ip flow-export ?
use layer 3 interface to configure ip flow command not layer 2
hello Sandeep thanks for correction  but it still doesnt accept it
6509(config)#ip flow-export ?
But when i do flow it gives few options .
6509(config)#flow ?
  exporter  Define a Flow Exporter
  hardware  Hardware config commands
  monitor   Define a Flow Monitor
  platform  Platform flow commands
  record    Define a Flow Record
Amit,
I think traditional NetFlow is not supported in 15.1SY, you have to use Flexible NetFlow:
Flexible Netflow Configuration Guide, Cisco IOS Release 15SY
Unfortunately I don't have any experience with Flexible NetFlow yet but this Cisco Live Session sounds interesting:
https://www.ciscolive.com/online/connect/sessionDetail.ww?SESSION_ID=6010&backBtn=true
"... The new Flexible NetFlow feature is covered in detail. ..."
Rolf
After comparing the data-sheets I think it actually depends on the supervisor-engine.
I guess you have a 2T?
amit bhatnagar
hello Thanks for reply ,
Yes my SUP is VS-SUP2T-10G , so if my understanding is right I cant use Netflow with SUP 2T ?
HI Amit,
SUP 2T supports Netflow with IOS is 15.1(1)SY1
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/white_paper_c11-652021.html
check this documents : whcih feature supported on ur IOS.
