netflow configuration SUP2T
cminard
I have problem configuring Netflow on 6500/SUP2T : it seems that standard commands do not exist on that SUP (ex : ip flow xxx).
I tried to configure flexible Netflow too but it applies only to routed interfaces ...
Perhaps the commands have changed for that SUP (as for QOS commands).
I am really new to netflow configuration.
Can anyone help me ?
I need only the very basic commands to configure.
Thanks in advance
Caroline
Reza Sharifi
Sup 2T has actualy more Netflow capabilities than the older sups.
Here is doc with config example:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/white_paper_c11-652021.html
Hi Reza,
Actually, I have configured flexible netflow already but no way to apply the "ip flow monitor" configured to the interface if in switchport state, I don't know why ...
With routed interfaces (no switchport), the command passes.
Unfortunately, I have only switchport interfaces configured (no routing on the 6500).
Any idea ?
Anyway, I will try to redo the config, based on the documentation you provided.
andtoth
Level 4
Level 4
Hi Caroline,
Netflow does not work on IPBase in 12.2(50)SY versions. You either need IPServices or higher or run 15.0(1)SY release or later.
Best regards,
Andras
