ā04-10-2012 02:12 PM - edited ā03-07-2019 06:03 AM
Hi guys,
Ive tried to configure NetFlow on layer 2 without success.
I configured the recond\monitor\exporter like the configuration guide said.
but still i dont receive any netflow traffic.
I checked the firewall on the VM and it looks fine.
Anyone have any idea??
i have done the command under the ethernet interface :" layer2-switch flow monitor TEST input" - for layer2 input.
ā04-10-2012 02:51 PM
ā04-10-2012 10:51 PM
Thanks for the fast replay!!
iam using version 5.1
here is sample of the configuration:
flow exporter scrutinizer
description netflow-tester
destination 192.168.1.212 - the netflow analyzer server ip address
version 9
source vlan 3 (192.168.1.211)
flow monitor TESTER
flow record netflow-original
** i did try to create my wn record for only layer2 data - without success.
After ive done this i start to add the interfaces i want to check.
int ethernet 2/1-2 - this is the uplink we want to test
layer2-switch flow monitor TESTER input
any idea`s?
ā04-11-2012 02:25 AM
Here is the configruation on the Nexus 7k
description export netflow to scrutinizer
destination 10.100.212.111
transport udp 6343
source Vlan3
version 9
flow monitor LIAD
record netflow layer2-switched input
interface port-channel1
layer2-switched flow monitor LIAD input
ā04-15-2012 01:59 AM
Does this entry appear in your FnF Record?
* collect datalink mac source address input
Found this on: http://www.bradreese.com/how-to/2-20-2011.htm
Jake
plixer.com
ā02-09-2014 12:31 PM
Hey,
Did you put "mac packet-classify" on the layer 2 link? SInce you are esentially placing a MAC ACL on the layer 2 interface when netflow is applied. This would be required to see IP traffic exported. Other wise only "non-ip" traffic will be exported, which I would imagine would not be very helpful here.
Also keep in mind that the netflow-original recorder is really designed for layer 3 traffic and doesn't have any relevant layer 2 information, See below:
Flow record netflow-original:
Description: Traditional IPv4 input NetFlow with origin ASs
No. of users: 1
Template ID: 258
Fields:
match ipv4 source address
match ipv4 destination address
match ip protocol
match ip tos
match transport source-port
match transport destination-port
match interface input
match interface output
match flow direction
collect routing source as
collect routing destination as
collect routing next-hop address ipv4
collect transport tcp flags
collect counter bytes
collect counter packets
collect timestamp sys-uptime first
collect timestamp sys-uptime last
This may not matter if you are putting this in between two routers, where the MAC's don't change, but you probably want to create you own recorder:
flow record layer2-netflow
match datalink mac source-address
match datalink mac destination-address
match datalink vlan
You can also add in any of the above information as well from netflow orginal depending on what you actually want to see.
Adam
