390W PoE-Budget for Cisco 3650-24 Port Model
mlinder01
Beginner
Beginner
Can anyone provide a "show power inline" with the available PoE-Budget for the new Cisco 3650-24 PoE+ Switch? We have to be sure that the 390W from the Datasheet is 100% correct.
Many thanks
Manuel
Reza Sharifi
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
I am not sure how many people have deployed 3650 series switches, as they are brand new.  If you are not sure about the documentation, ask your system engineer to clarify it for you.
Recognize Your Peers
