NetFlow on 3750
imranraheel
I have a 370 with C3KX-NM-10G module & i want to enable NetFlow on it did the specified configs
Step 1 Flexible NetFlow Flow Records
flow record miketest
match datalink source-vlan-id
match datalink dot1q priority
match datalink mac source-address
match datalink mac destination-address
match ipv4 version
match ipv4 tos
match ipv4 ttl
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
match interface input physical snmp
collect interface output snmp
collect counter flows
collect counter bytes
collect counter packets
collect timestamp sys-uptime first
collect timestamp sys-uptime last
flow record miketestegress
match datalink destination-vlan-id
  match ipv4 version
  match ipv4 tos
  match ipv4 ttl
  match ipv4 protocol
  match interface output physical snmp
  collect interface input snmp
Step 2 Flexible NetFlow Flow Exporter
Flow exporter export-to-samplicator
Destination 10.1.1.8
source Vlan1
Transport udp 2055
option interface-table timeout 60
Step 3 Flexible NetFlow Flow Monitors
# Tie the Flow Monitor to the Flow Record
flow monitor mikektest
record miketest
cache timeout active 60
flow monitor mikektestegress
& Applied it to g1/1/1 but without any luck , plecse let me know if netflow works on the
TenGigabitEthernet1/1/1 &
TenGigabitEthernet1/1/2
Only i have four switches stacked and nothing plugged to the
C3KX-NM-10G module
jakewilson
You only get NetFlow on the 10G uplinks of the 3KX.  The blog in that link explains.
Please vote on my reply if it helps you solve the problem.
Jake
