Netflow on C3750X
zheepern0826
Hi guys,
I am trying to configure my C3750X(ip base) switch to send the netflow ingress and egress on uplink to a netflow collector.
My switch model is WS-C3750X-48PF-S and the module I am using is C3KX-NM-10G
So far below is my configuration in the switch:
ip flow-cache timeout active 5
ip flow-export source Vlan250
ip flow-export version 9
ip flow-export destination 10.4.2.240 9995
interface GigabitEthernet1/1/1
switchport trunk allowed vlan 226,233,250,833,1002-1005
switchport mode trunk
ip flow ingress
ip flow egress
After configure the switch as above, I still unable to received any data from my netflow collector. Below is some verification command on switch.
SW1#sh ip flow export
Flow export v9 is enabled for main cache
Export source and destination details :
VRF ID : Default
Source(1) 10.32.250.76 (Vlan250)
Destination(1) 10.4.2.240 (9995)
Version 9 flow records
0 flows exported in 0 udp datagrams
0 flows failed due to lack of export packet
0 export packets were sent up to process level
SW1#sh ip cache flow
IP packet size distribution (0 total packets):
1-32 64 96 128 160 192 224 256 288 320 352 384 416 448 480
.000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000
512 544 576 1024 1536 2048 2560 3072 3584 4096 4608
IP Flow Switching Cache, 278544 bytes
0 active, 4096 inactive, 0 added
0 ager polls, 0 flow alloc failures
Active flows timeout in 5 minutes
Inactive flows timeout in 15 seconds
IP Sub Flow Cache, 33608 bytes
0 active, 1024 inactive, 0 added, 0 added to flow
0 alloc failures, 0 force free
1 chunk, 1 chunk added
last clearing of statistics never
Protocol Total Flows Packets Bytes Packets Active(Sec) Idle(Sec)
-------- Flows /Sec /Flow /Pkt /Sec /Flow /Flow
SrcIf SrcIPaddress DstIf DstIPaddress Pr SrcP DstP Pkts
SW1#
Can anyone advise did i configure correctly or where did i missed.
Thank you very much in advance.
Mark Malone
Hey
You have applied an ip command to a layer 2 switchport , you need to put it under the vlan interface to get flows , netflow works at layer 3
ip flow ingress
ip flow egress
7 Replies 7
Mark Malone
Hey
ip flow ingress
ip flow egress
So means i shouldn't put in Gi1/1/1 as it is a layer 2 switchport and I should put the command in vlan interface ?
Is it correct if i configure it as below ?
interface Vlan250
description MANAGEMENT-VLAN
ip address 10.32.250.76 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
Thank you very much
Yes that's it netflow goes on ip based interface , if there's more than 1 put it on each ip interface you want a flow from and it will collect the flows from each
Hi Mark,
I have tested and it works.
Thank you very much on the explanation and guidance.
ah great glad its showing something
Hi Mark,
Actually I am just configure netflow on the access switches for testing purpose. I have install a new monitoring and try to play around and take this time to learn and understand the networking.
Will try to get approval to put the configure netflow in core switch. Thanks again for your help and guidance.
remember if this is purely a layer 2 switch you wont get many flows as netflow works on ip based flows ,designed for layer 3 interfaces , if you only have a mgmnt interface depending on the software your exporting to it may only show it as a reachable device , to get a good flow with all different types of protocols etc you would put it on your wan links or layer 3 links like ion distribution switch port-channels that are ip based
