netflow on internet edge router
elite2010
Level 3
Level 3
If i want to enable  netflow on the internet edge router (Cisco CISCO3945) and behind asa firewall in active standby mode ?
What is the pros and cons
Thank you
johnd2310
Level 8
Level 8
This all depends on how much traffic the 3945 is passing and the cpu utilisation on the router. If the cpu utilisation is not too high, implementing netflow would be a good idea. The pros are 1) visibility into traffic traversing the edge router 2)security incident detection
I don't have any cons for implementing netflow, i think it is a great tool for visibility into traffic that is traversing the network.
John
**Please rate posts you find helpful**
