NetFlow on L2 Switchport
kashi_login
Is it possible to configure NetFlow on L2 gig switchport on a multilayer switch running native IOS ?
How else can it be done and what tool can be used to view traffic visibility as seen via Netflow
5 Replies 5
Using the explicit cmd will i be able to export the traffic flowing through the trunk links to NetFlow Analyzer.
wandering_997
Yes, it is.
And nfdump is a quite good ipflow analyzer.
Wandering
Can nfdump be run on windows and what cmds need to be configured on l2 switchports to forward NF packets to nfdump ?
palace
This is link broken, or no longer available?
I'm facing the same issue right now, that was stated above.  My uplink port to our router is configured as a switchport, but I would like to set this as the NetFlow destination.  Is this possible?
C
