Netflow on Nexus 7K ver 6.2.8b with two L2 & L3 flows?
rizwanr74
Level 7
Level 7
Hi guys,
I want to enable netflow on our core switch 7K running ver 6.2.8b and so I copied below lines in table 1, and I see netflow is being received on Solarwind NTA.
table 1:
feature netflow
flow timeout inactive 15
flow timeout active 60
flow exporter solrwin-flowexport
  destination 10.1.1.1
  transport udp 2055
  source Vlan10
  version 9
    template data timeout 60
flow record solrwin-flowrecord
  description Solarwinds Netflow traffic
  match ipv4 source address
  match ipv4 destination address
  match ip protocol
  match ip tos
  match transport source-port
  match transport destination-port
  collect counter bytes
  collect counter packets
flow monitor solrwin-flowmonitor
  description Send Netflow to Orion NTA
interface Vlan10
  ip flow monitor solrwin-flowmonitor input
  ip flow monitor solrwin-flowmonitor output
Later I was told that I must enable a layer2 netflow as well, with below commands, shown in table 2.
Tabe 2:
flow record L2solrwin-flowrecord record solrwin-flowrecord
  match datalink mac source-address
  match datalink mac destination-address
  match datalink vlan
flow exporter L2solrwin-flowexport
  transport udp 2055
  source Vlan10
  version 9
flow monitor L2-solrwin-flowmonitor
interface Ethernet1/46
  layer2-switched flow monitor L2solrwin-flowmonitor input
I got two questions, question one: Do I need two separate flows configuration in order to capture netflow correctly?
Question two: Can I combine L2 and L3 flow configurations into one as shown below in table 3?
Table 3:
  transport udp 2055
  source Vlan10
  version 9
  match datalink vlan
  match ip protocol
  match ip tos
interface Vlan10
layer2-switched flow monitor solrwin-flowmonitor input
0 Replies 0
