HTTPS Traffic Flow across cisco routers being blocked/failed
zposton59
Community Member
We have a new monitor software that we are trying to deploy in our environment. It uses an agent that is installed on windows. The agent is having trouble communicating across a T1 tunnel from one of our remote sites and out the firewall at our HQ. To better explain the flow I'll give you a flow diagram.
Remote Site (C1900) > T1 Tunnel > HQ (C1900) > HQ Switch (C3560) > HQ Router (C2600) > HQ Firewall (ASA5510) > Internet
The agent communicates via HTTPS. I've even noticed that some HTTPS websites won't load from this site, but some do. I have confirmed that HTTPS traffic is going to one of the IP's for the monitoring software and coming back in on the firewall via capture commands. My biggest issue is I don't know how to troubleshoot this on the C1900 or the C2600 because they don't have the capture or packet-tracer tools.
If someone could provide some assistance that would be awesome.
I don't know what all information you guys need so feel free to ask and I'll do the best to provide the info you need to assist.
Zach
Boris Uskov
Level 9
Level 9
Yes, it is realy not very easy to find, where the trafic is stuck. I can suggest two things for cisco Routers. The firtst and easiest way is to use Access-lists and their counters. For examle, you can create an access-list
ip access-list extended acl-test-https
 permit tcp any eq 443 any log
 permit ip any any
ip access-list log-update threshold 1
And after that you can add this ACL to inside interfaces of all cisco Routers in output direction. You can use
show ip access-list acl-test-https
and
show logging
to find out, if the return traffic appears on inside interfaces of Routers.
The second thing, is to use packet capture for 1900 Routers. The Cisco ISR G2 routers mostly support packet capture (similar to cisco ASA), but I'm not sure about an old one 2600 Router. Here is a brief example of the configuration and usage of EMBEDDED PACKET CAPTURE for IOS Routers:
http://www.firewall.cx/cisco-technical-knowledgebase/cisco-routers/1089-cisco-router-embedded-packet-capture-configuration-usage-troubleshooting-exporting.html
ahmede_2
How about HTTP, does it work?
You might have a problem with your MTU size.
The simple way to check is to change the DF to 0 (create route map that matches all traffic and then set ip df 0)  and test.
