Netflow on Sup2T
LooseCannon
Community Member
Hi all,
I was hoping someone might be able to shed some light on this as I have been unable to find anything online.  About five months ago I configured Netflow on two 6504-E's that have Sup2T engines in them.  Netflow was added to several SVI interfaces and it was exporting properly to a Netflow analyzer.  However, it appears those flows stopped several months ago.  So, I logged in to the switches and had a look and everything still seemed to be configured correctly except that none of the flows were being exported.  My next step was to remove the flow monitor from each interface and then I was going to re-apply it.  However, this is what I am seeing when I go to apply it:
(config-if)#no ip flow monitor WM-Monitor input
(config-if)#no ip flow monitor WM-Monitor output
(config-if)#ip flow monitor WM-Monitor input
% Flow Monitor: Flow Monitor 'WM-Monitor' is currently having its old cache deleted.
I thought that it might need a bit of time to delete the cache but even after a day I still can't re-apply it.  Likewise I cannot even remove the monitor as it still thinks it is applied to the interface, even when it is not:
(config)#no flow monitor WM-Monitor
% Flow Monitor: Flow Monitor is in use. Remove from all interfaces before deleting.
#show flow monitor WM-Monitor statistics
  Cache type:                               Normal (Platform cache)
  Cache size:                              Unknown
  Current entries:                               0
#show flow monitor WM-Monitor cache
% Flow Monitor: 'WM-Monitor' has no cache.
At this point I am at a loss.  The problem happened on both 6504-E's that I had this configured on.  I will post the rest of the Netflow config below just for a reference.  Is it possible I have run into a bug here?
flow record WM-Record
description nfsen Netflow v9 Record
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
match interface input
collect routing source as
collect routing destination as
collect counter bytes
collect counter packets
collect timestamp sys-uptime first
collect timestamp sys-uptime last
flow exporter WM-Exporter
description nfsen Netflow v9 Exporter
destination x.x.x.x
source Loopback0
transport udp 2055
description nfsen Netflow v9 Monitor
record WM-Record
flow hardware export threshold 60
10 Replies 10
Reza Sharifi
Can you try deleting the entire Netflow config and reapplying again?
Hi Reza,
Thanks for the reponse.  I can't remove the entire config as the moment I try to remove the flow monitor that I have created it still thinks it is assigned to the interfaces,even though I have clearly removed it from all interfaces.  So at this point I cannot assign it to any interfaces nor can I remove the configuration entirely.  That leads me to believe I have encountered a possible bug.
What version of IOS are you running?
Can you post?
sh ver
Running 15.1(1)SY on both 6504-E's
s2t54-advipservicesk9-mz.SPA.151-1.SY.bin
I could be a bug. Since your sup is 2T and I am sure under server contract, open a ticket with TAC.
Confirmed that is the bug.
CSCui17732
  Sup2T: show tech-support hangs VTY session on Netflow TCAM interrupt
  CSCui17732
  Description
  Symptom:
  One or more following symptoms may be observed:
  "show tech-support" command is not completed, and VTY session hangs
  Netflow entries are not created
  Netflow may stop or skip exporting data
  Conditions:
  Issue is seen with 15.1(1)SY or later releases.
  AND
  The switch reports Netflow TCAM error messages.
  Example:
  %EARL_L3_ASIC-3-INTR_FATAL: EARL L3 ASIC 0: fatal interrupt NF_SE_CMD_ERR
  Workaround:
  If the issue is seen with a DFC-enabled module, sometimes reset the module may solve this issue, If it is not
  solving then we need to reload whole box.
  For standalone switch:
  Sup2T#hw-module module reset
  For VSS setup:
  Sup2T-VSS#hw-module switch module reset
  If the issue is seen with the Sup engine, then failover.
  Sup2T#redundancy force-switchover
  Please be aware that resetting sup/module resolves the problem temporarily and issue may return at any time.
  Further Problem Description:
  The bug fixes the symptoms mentioned above, not the actual error message.
The error can be ignored after this
  fix.
  Customer Visible
  Was the description about this Bug Helpful?
  (3)
  Details
  Last Modified:
  Aug 28,2014
  Status:
  Fixed
  Severity:
  2 Severe
  Product:
  Cisco Catalyst 6000 Series Switches
  Support Cases:
  72
  Known Affected Releases:
(5)
  15.1(1)SY
  15.2(1)SY
  15.1(2)SY
  15.1(1)SY1
  15.1(1.2)
  Known Fixed Releases:
(9)
  15.1(1)IB273.251
  15.0(0)SY99.335
  15.1(2)SY1.1
  15.1(1)IC66.64
  15.1(99)SY9.1
  15.0(1)SY6
  15.1(1)ICB29.36
  15.1(2)SY2
  15.1(1)SY3
edwardzeng
Level 3
Level 3
To check which interfaces are using the netflow by "show flow interfac"
daniele matta
Hi I am running similar problem with the sup2t and netflow ,
I have tried different configuration as my server collector had always problem with flows timeout.
Then I configured:
flow platform cache timeout active 300
flow platform cache timeout inactive 60
After this, i solved the timeout problem, but suddendly after several hours the netflow stop working at all.
No flows were generated anymore and any show flow monitor comand was stacking the router
Plus i couldn't play any flow comand even removing the ip flow monitor from the interface
After I tried other times no ip flow monitor / ip flow monitor the router started again to works with the flow parts.
Can someone help me with this?
Hi there,
I ended up opening a ticket with TAC about this and the bug was eventually resolved.  We have been running 15.1(2)SY2 for roughly 6 months now without a recurrence of the problem.  I'm sorry I don't have the exact bug ID but if you search the release notes for Netflow you will see a note related to fixing this particular bug.
May I ask you your  netflow configuration?
