netflow supportable in WS-C3560G-24TS?
nagasheshu.2014
Hi All,
Please can you help me with below question.
Is netflow supportable in WS-C3560G-24TS? If so, In Which IOS version and do we need any additional licenses?
We have WS-C3560G-24TS with below IOS doesn't look to be supporting.
Cisco IOS Software, C3560 Software (C3560-IPBASE-M), Version 12.2(25)SEE2, RELEASE SOFTWARE (fc1)
3560G(config)#ip fl?
% Unrecognized command
3560G(config)#ip fl
Please let me know if you need more information.
5 Replies 5
Joseph W. Doherty
On the 1st gen 3560s, I recall Netflow isn't support.
On the 2nd gen 3560s, I recall there was a 10g service module that provided some Netflow support (I also recall only for the module ports).
Thanks Joseph, How do i know which generation is mine?
Please find show version from switch.
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Fri 28-Jul-06 07:19 by yenanh
Image text-base: 0x00003000, data-base: 0x00EB0F14
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(25r)SEE4, RELEASE SOFTWARE (fc1)
NET258A-READINGDC.CE1 uptime is 37 weeks, 6 days, 12 hours, 29 minutes
System restarted at 01:35:33 BST Thu Oct 6 2016
System image file is "flash:c3560-ipbase-mz.122-25.SEE2/c3560-ipbase-mz.122-25.SEE2.bin"
cisco WS-C3560G-24TS (PowerPC405) processor (revision D0) with 118784K/12280K bytes of memory.
Processor board ID FOC1103Z8GC
Last reset from power-on
11 Virtual Ethernet interfaces
28 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:1A:E2:CD:A5:80
Motherboard assembly number     : 73-10215-04
Power supply part number        : 341-0098-02
Motherboard serial number       : FOC11025UYR
Power supply serial number      : AZS110100SZ
Model revision number           : D0
Motherboard revision number     : B0
Model number                    : WS-C3560G-24TS-S
System serial number            : FOC1103Z8GC
Top Assembly Part Number        : 800-26851-01
Top Assembly Revision Number    : A0
Version ID                      : V03
CLEI Code Number                : CNMW200ARC
Hardware Board Revision Number  : 0x09
Switch   Ports  Model              SW Version              SW Image
*    1   28     WS-C3560G-24TS     12.2(25)SEE2            C3560-IPBASE-M
Configuration register is 0xF
show inventory
NAME: "1", DESCR: "WS-C3560G-24TS"
PID: WS-C3560G-24TS-S  , VID: V03, SN: FOC1103Z8GC
your 3560G doesn't support netflow for sure.
On 3560v2 netflow was not supported as well.
On 3560-X netflow was supported on ports of networ services module.
On successor - current 3650 - netflow is supported in new code.
Stepan
Thanks Stepan.
3560/3560G were 1st Gen ("peers" of 3750 StackWise).
3560E/3560-X were 2nd Gen ("peers" of 3750 StackWisePlus).  The 2nd Gen support a module.
