NetFlow
yuchenglai
Hi, I was wondering if NetFlow is able to see packets that traverse layer 3 interfaces on a VRF.  If so, what is the minimum hardware and software required.
5 Replies 5
Jan Nejman
Level 3
Level 3
yes you can see a flow information from VRF in the netflow export. "packets" is not right word. You can see information about flow - source&destination IP, # bytes, # packets, src/dst interfaces, ports, protocol, etc.
You can find many netflow analyzer developers. See: http://netflow.caligare.com/applications.htm for the detail.
Kind regards
Jan Nejman
Caligare, Co.
http://www.caligare.com/
Giuseppe Larosa
Hello David,
support for egress (outbound) flows on interfaces associated with a VRF has been introduced with "MPLS egress netflow accounting" feature
see
http://www.cisco.com/en/US/docs/ios/12_1t/12_1t5/feature/guide/egress.html#wp1015329
A very good tool for searches is Feature navigator
http://www.cisco.com/go/fn
do search by feature and in the new window you can search all features containing the word Netflow
MPLS egress netflow accounting is supported practically on all devices that can act as a PE node (where you can configure an MPLS VRF)
since 12.1(5)T.
even on C3640 or C2650XM
all you need is the command
mpls netflow egress
in interface configuration mode
To be noted a very new feature to account traffic in ingress direction has been introduced in new 15.0M IOS
http://www.cisco.com/en/US/docs/ios/fnetflow/configuration/guide/cust_fnflow_rec_mon.html#wp1068360
But the older feature should be enough for standard needs.
Hope to help
Giuseppe
jakewilson
Hi David,
We are in the midst of some NetFlow research with VRF as well.  Ingress, Egress, etc. we support it, but more specifically, we are trying to learn more about the types of reports people want access to. So I have a rhetorical for you "what reports do you want beyond 'packets' or 'flow'?  Do you need to see any MPLS details?
Jake
Jake,
I don't have a need to see MPLS traffic as of yet.
David Lai
Network Engineer
Brooke Army Medical Center
Jake,
Is there any NetFlow capability on VRFs on 6500 series switches?
David Lai
Network Engineer
