Netflow
jonk34567
Level 6
Level 6
i have entered the below configuration on my cisco router for collecting netflow information.
R1(config)#ip flow-export destination 192.168.30.134
R1(config)#ip flow-export version 9
R1(config)#interface f0/0
R1(config-if)#ip flow egress
R1(config-if)#exit
when i enter " show ip cache flow " it does not show any egress data.why ? although many traffic are originating from my device.
Georg Pauwen
try and enable ingress as well:
R1(config-if)#ip flow ingress
What is the output of 'show ip cache flow' now ?
shows only ingress traffic. it does not show any egress traffic
which device is this on, and which IOS version are you running ?
Cisco Router 1941 and version 15.2. Is my configuration correct ?
